Tub continues to fill and overflows into room, can't get it to work in any other setting besides fill
    President:
  • 1,776 Answers
This is caused by a faulty water level switch. This is a diaphragm like device with a small clear plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level rises, pressure increases on the air in the tube and when it reaches a certain level, it activates the switch and turns off the water, and signals the timer to begin agitating. Make sure that there are no obstructions in the tube. The switch can be checked with a multimeter for continuity. No continuity means the switch is bad. Hope this helped and best wishes.
Posted on Jul 31, 2009
Why do the stackable washers always overflow with water. Is it a sensor problem or what?
Overflowing can be caused by a faulty pressure switch or tube from switch to the tub. It is operated by air pressure from water filling in the tub. If this does not activate then the inlet valve will continue to allow water to enter the machine. If it is overflowing during spin only it is most likely something obstructing the pump. If it is filling the tub even when the machine is off the problem is the inlet valve.
Jun 28, 2010 | Maytag LSE7806A Top Load Stacked...
My washing machine keeps overflowing whats wrong
Top load or front? If top loader, the pressure fill switch may be unplugged or broken. Hose leads from the switch to the tub. If the hose is disconnected or has a hole in it, or is plugged the washer will continue to fill with no shutoff.
Nov 19, 2009 | Car Audio & Video
Machine over fills with water and will not agitate
If the washer overfills, it may be something as simple as a detached or broken air hose on the pressure switch. The following link explains:
http://www.fixya.com/support/r762094-washer_overflows
The pressure switch on top loaders is located behind the load level selector knob on the operator console. The pressure switch on front loaders will be located inside the cabinet, usually mounted along the back interior wall. In the case of certain Maytag front loaders, the pressure switch is actually located under the tub. The principles of operation on all of them is the same, though. They all have an electrical connection and an air hose that detects the pressure from the tub as the water level rises.
If the pressure switch is not able to detect the water level properly, it will not shut off and the washer will never begin the wash cycle. Instead, you get a tub overflowing on your laundry room floor.
Read through the link provided and let me know if you have any questions. I hope this helps you.
NOTE: Another source of an overflow could be the water inlet valve. This is usually a slow fill fill that you find when the washer is sitting idle over night. A quick test to determine the source of the problem is to unplug the washer. If the water stops - pressure switch. If the water continues to fill - water inlet valve.
Let me know what you find...
Aug 12, 2009 | Washing Machines
Ultimate Care II - water doesn't stop at the fill line, keeps filling to overflow and will not agitate
If you have questions, please let me know. I hope this helps you.
Aug 10, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
What would cause the washer to overfill the tub?
If water is overflowing and you disconnect power to the machine. then:
A. It continues to fill: Replace water fill valve. (the part the fill hoses screw onto)
B. It stops filling: Most likely has a plugged tube from the tub to the water level switch.
Jul 27, 2009 | Washing Machines
Water continues to fill and overflows
1.Drain hose is too low. Minimum 30 inches from the floor.2.Water fill valve is defective. If it fills with timer set to OFF,replace the water fill valve.
3. The Air hose from the tub to the water level valve is pinched or stopped up with soap scum. Check the air hose for a pin hole,pinched or obstructed..
Jun 27, 2009 | Whirlpool Washing Machines
Kenmore 80 Series Overflow
We've now had this happen three times and the exact same thing caused it all three times.
If the water level selector knob hasn't "clicked" into one of the given load levels on the control panel(i.e. the knob is in between levels) it will continue to fill until you discover water everywhere and turn the knob until it "clicks" into a level.
As far as I know, it has nothing to do with loose hoses or bad switches, it's bad design. There seems to be no safety mechanism to turn off the water if you over- or under-shoot the desired water level.
Apr 29, 2009 | Kenmore 24032\24036 Top Load Washer
Hot water continues to run after rinse, filling tub overflowing
sounds like you are right the water inlet solenoid on the hot side is sticking remove the hoses and clean th escreen out and the valve try agin with a fill on hot to see if it stops on a small load if not replace the water inlet valve
Mar 15, 2008 | GE WVSR1060A Top Load Washer
Cold Water Solenoid Problem
The fill switch has a diaphragm that could be damaged and not closing properly. I have personally experienced this problem before. The way water could be getting by the switch (even with no power applied) is simply water pressure in the lines. I don't understand why it would work during the spin and rinse cycles, however. If you say it's not a pressure switch problem (level sensor), then I would invest in a new fill valve. I hope this helps.
Jul 08, 2007 | Hotpoint VBXR1070W
Washing Machines Logo
Top Washing Machines Experts
