Question about Microsoft Windows Vista Ultimate Edition
Soon after boot up my o.s remains bussy for quite a time and RAM meter shows 80-90%usage. also cpu is engaged up to 80% for more than 5 minutes.is this normal?
    President:
  • 627 Answers
No. Maybe you have virus on your computer
Use an antivirus program
Also chek in startup which files are loading
You can click on start - run type msconfig and uncheck all links that you don't need
Posted on Jul 31, 2009
D101GGC mother board makes long beeps and fail to boot up. I removed rams, dvd rom, floppy drive, hdd and finally removed the cmos battery for a minute and put it back. it failed to boot up. But once I...
The fact that the board is making a long beep is usually a sign of a memory problem. This may be the RAM has failed (try with one stick at a time or some new RAM ) But, it could be more serious- The memory controller can also cause the same problem. This can be on the motherboard or part of the processor. Your motherboard is now obsolete as there have been at least 2 new CPU sockets released since. You motherboard is old and so the problem is most likely to be a failed onboard memory controller. But, try the RAM first if the fault remains I would suggest a new board. Sorry!
Apr 17, 2013 | Computers & Internet
I bought my new Sony Vaio VPCEH last 2 weeks ago,. dual core, 2.3ghz, 4gb ram.. what i wondered is why my cpu almost overload all the time even i just use firefox, or explorer (opening folders ) or so
The CPU is runnimg with a useage of 45-60% as soon as the laptop has booted up because Kapersky is upgrading the virus definition file and is running a virus check on the files stored on the hard disk. When Kapersky has finished these tasks then you will see a drop in CPU useage.
NOTE as you install more programs and as your data files increase so will it take longer for Kapersky to carry out the virus scan.
Apr 18, 2012 | Sony Computers & Internet
Hi everyone, I have HP Compaq6910 notebook. The problem is that when it start windows it was too slow. It will take almost 3 minutes to display the Windows loading bar and another 3 minutes to log in to...
Sounds like you have to many startup programs. Check msconfighttp://www.liutilities.com/products/wintaskspro/processlibrary
Don't download or scan anything they ask but it tells what each processor does so you can manually check which ones you obviously don't need and then uncheck them and choose selective startup.
Your boot time will be much faster. Obviously you want all the neccessary startup files to boot so only uncheck the ones you know you don't need at startup.
I think thats why your screen takes so long to boot.
Nov 14, 2009 | HP Compaq 6910p Notebook PC PC Notebook
Intel DG965RY CPU Overheating
Check the clamp of the cooling fan. If the clamp is not engaged, heat sink didn't take the heat away from the micro processor causing CPU over heating.
Jul 03, 2009 | Intel DG965RY Motherboard
Mac OS 10.5.7 high user account CPU usage
Hi.Maybe you don't let your notebook get the air that must take.Probably if you have it on your feet on bed the macbook cannot breathe.Check this software out if you need further information about your computer's hardware temperature.
http://www.almico.com/sfdownload.php.
Jun 22, 2009 | Apple MacBook Pro Laptop Computer with...
I have a AcerPower FH P4 -- 100% CPU usage all the time prob...
Boot your PC into "Safe Mode" (tapping the F8 key on boot to get to the option) and run a full/complete Virus scan with Anti Virus with up to date virus definitions and see what that yields.
Feb 09, 2009 | AcerPower FH - P4 631 3 GHz (S6463624) PC...
Few questions about RAM memory?
Solution:
i)  LOW DENSITY modules have 100% compatiility with ALL systems and ALL chipsets.
    HIGH DENSITY modules only have 10% compatibility
    here compatablity means LOW DENSITY RAM are accepted by all system(100%)  or any make           system.. HIGH DENSITY RAM are accepted by 10% by only some system or computers...
ii) in order to check system performance or amount of Computer RAM usage press the ctrl+alt+del
   simultaneously a new window(window task manager) will appear showing:
    CPU usage: showing the amount of CPU or processor utilized at that particular time.
    PF usage: showing the amount of RAM memory utilized at that particular time.
    Physical Memory: showing Total RAM Memory, Available Ram memory....
iii) baiscally they are two types of RAM they are:
    DDR1:which is older one supported by older system  or older mother boards which is costlier
    DDR2: which is latest one supported by all new system or new mother boards which is less                         costlier
    DDR: double data rated ram......which will send data at a double rate compared to SD RAM
iii) here color doesnt matter, these slots either support DDR1 or DDR2 but not both at a time
    DDR1 has 184 pins or gold plated pinssss... on the edge of the RAM
    DDR2 has 240 pins
    so difference doesnot allow DDR2 to placed in DDR1 motherboards or vice versa...
iv) it does have anything to do with no of chips on the RAM but they only differ whether it is DDR1 OR DDR 2(DDR2 are much faster than DDR1)
NOTE: whatever may the the RAM, each RAM has FSB(called Frequency...) which determines the frequency of rate at which data is tranferred from RAM to processor(CPU)  usually in MHZ such as FSB 300, 400, 200 , 333...................
more the FSB the faster data is transferred to the processor(CPU)
dont worry even RAM with less FSB's work well with the processor....having 1 GB RAM or 2 GB RAM is engouh, it only matters with the speed of CPU ... but not RAM......
Sep 24, 2008 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
Microsoft Windows Vista Ultimate Edition Logo
122 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
