Question about Tomtom RIDER GPS Devices
Over loaded via 12volt mains adaptor
Overloaded via 12volt mains adaptor.. my son got hold of my (tomtom rider 2nd edition), found it to have no charge and tried to charge it with the mains adaptor that he has for plugging his hand held games into. overloading the device with 12 volts rather than the lower voltage given by the tomtom mains charger supplied with the device... is it repairable?
    Brigadier General:
  • 4,090 Answers
At great expense cheaper to buy a new one
Posted on Aug 01, 2009
Tom tom troubleshooting
press and hold down both buttons on the head set until blue and red lights flash like crazy, then it is in discovery mode and redo the the find device on the tomtom screen
Jul 16, 2014 | Tomtom RIDER 2nd Edition GPS
Thm Tom Rider 2 can't call out while riding
The tomtom is made so you can only receave calls when you are moveing. you can't call out.
Jul 31, 2008 | Tomtom RIDER 2nd Edition GPS
Can you tell me where is the reset button on tom tom 1 IQ
I'm a little confused about which unit you have, but the answer is simple enough..... If there isn't a small hole on the bottom of the GPS, then simply hold the on/off button for approximately 15 seconds -- until the unit restarts. The small "hole" that I'm referring to will be in the same vicinity as the connector that the cable plugs into. It should say reset right by it, if the reset button is there. If you do have a reset button on the bottom of the device, you'll need to use something to press the button. A paper clip straightened out a bit works perfectly.
The following lists are from Tom Tom's website. I hope this helps:
Devices that are reset by holding the On/Off button ico_open.gif
(GO x50, Blue&Me TomTom, GO x40,
XL IQ Routes, XL,
ONE IQ Routes,
Rider Pro, Urban Rider)
(GO x30, GO x20, GO x10, GO,
XL IQ Routes ², ONE XL,
ONE 3rd Edition, ONE 2nd Edition, ONE 1st Edition
TOYOTA, ECLIPSE, DAIHATSU, ECLIPSE II,
Toyota Aygo Connect Multimedia,
Start ², Start
RIDER 2nd, RIDER 1st)
Apr 29, 2011 | Tomtom ONE 3rd Edition GPS
MY HEAD SET HAS NO CONNECTION WITH THE DEVICE (TOM TOM RIDER 2ND EDITION). THE DEVICE CAN NOT FIND THE BLUETOOTH HEADSET
Reset the unit by pressing the small pin hole button. Do this when the unit is on. let it reboot by itself and try again to pair ur phone/blutooth.
Hope this helps. let me know if not.
Aug 11, 2010 | Tomtom RIDER 2nd Edition GPS
I have a TomTom Rider 2nd Edition. I need to restore the SD card how can I get this done.
You can purhcase the new TomTom Rider 2 map update for $79 from TomTom.
If you have your receipt as proof of purhcase, you maybe able to take it back to the retail store you purhcased it from and see if they can assit you with TomTom.
Contact TomTom customer support directly to see if they can assist you also.
Good luck
Apr 03, 2010 | Tomtom RIDER GPS Devices
Rider 2 Bike Dock no longer charges, needs repairing or replacing?
call tomtom to get the dock replace, after you insure that the dock is getting power. check with ohm meter, should have abut 13.5 volts to the base.
Aug 21, 2009 | Tomtom RIDER 2nd Edition GPS Receiver
Restore to factory setting
n rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. The only information lost on your device is the clock’s time zone setting. Select your device from the list below to see how to reset it.
Select your device: TomTom GO 940/740/540 TomTom GO 930/730/630/530 TomTom GO 920/720/520 TomTom GO 910/710/510 TomTom GO, GO 300/500/700 TomTom XL IQ Routes TomTom XL (30-Series) TomTom ONE XL TomTom ONE IQ Routes TomTom ONE 30 Series TomTom ONE 3rd Edition TomTom ONE 2nd Edition TomTom ONE 1st Edition TomTom RIDER 1st Edition, RIDER 2nd Edition TomTom ECLIPSE II TomTom DAIHATSU, TomTom ECLIPSE, TomTom TOYOTA Help Not sure which device you have? ico_close.gif Type the first two characters of your device's serial number below to find out.
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
The rest button is on the top of the GPS
Jul 23, 2009 | Tomtom GO 910 GPS Receiver
Tomtom Rider GPS won't turn on
My Rider 1 is showing the same sympton. Was working fine now I can't get past the initial "Tomtom" screen.
Does it power up when connected to the mains charger?- No, need to prod reset and then turn on manually.
Does it switch on when connected to the bike cradle? - No, only sign of life if by manually turning on but only get as far as the Tomtom screen, not the main menu.
Any ideas welcome
Jul 14, 2009 | Tomtom RIDER GPS Devices
Need tomtom rider 2 2nd addition docking shoe
Forget TomTom. Go buy this one
http://www.wunderlichamerica.com/mm5/merchant.mvc?Screen=PROD&Store_Code=WA&Product_Code=8600880&Category_Code=
I talked to TomTom multiple times on the phone and had same problem but finally found this. It's better quality and it's available.
Mar 24, 2009 | Tomtom RIDER 2nd Edition GPS
Tomtom RIDER GPS Devices Logo
379 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
