Question about Tappan MGF500PBW Gas Kitchen Range
Frigidaire convection free standing range
Had a ge gas range installed a frigidarie convection gas range i have propane gas i unhooked the old unit and installed the new unit but am getting black soot on the bottome of the pot did i do something wrong or need i do something else??? also the oven flames seem larger
  • 213 Answers
New ranges come set for natural gas. in the installation instuctions there should be instruction for converting the range to lp. some models require that the orafice for the burners be replaced as part of the coversion, if so the there should be a pack of them with the new range. others you just have to tighten the orafices that are all ready in the range. you installation guide will tell you which one you have to do
Posted on Nov 25, 2007
Convert ge pgs975 to propane
You should be able to contact either GE or the shop you purchased it from & get a gas jet kit for it, which will make the conversion for you. They are pretty simple & can be installed by anyone with reasonable DIY skills. If you are not that person, it is a simple enough job that it should not be outrageously expensive. If you have a local heating & air conditioning person you trust they can make the change over for you & will probably be more reasonable on price.
Jan 30, 2014 | General Electric Profile PGS975 Range
Flame to low
Your problem could be or probably is with the regulator...not enough gaspressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Jul 09, 2011 | Frigidaire Gallery 30" Self-Cleaning...
My Frigidaire FGFL67DBF gas oven does not reach the temperature set. I tried to calibrating the control, but it did not work. Any suggestions?
I believe that you have a convection oven.... by design, convection ovens built by GE come up to temperature....at 25 degrees below the set level .... when the Convection function is enabled.
Oct 15, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Gas Range oven light doesn't work even after changing
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Flames inside oven appear too high
It should have been obvious to the GE repair person that something requires adjustment or replacement.
Feb 01, 2018 | GE Profile 30" Self-Cleaning Freestanding...
Installation of gas convection oven range
check the specs on the oven you are planning to buy(the retailer should be able to provide this imformation)they should give you a recommended location for the gas feed in relation to the oven.the feed will need to be relocated to this location.if you are not comfortable doing this yourself (always use caution & common sense when working with natural gas).i would call in a proffesional,alot of times your local gas company will do this for a nominal fee,somtimes for free.hope this helps.thanx for using fix-ya!!!
Nov 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge profile JGS968 fan comes on no ignition on gas bake convection bake and roast . Only broiler works otherwise themp always read 100 Degress
natural gas or propane? is this a brand new stove? or did this just start happening? is the gas shut off at the oven turned on? there are saftey features that shut off the gas so you dont get hurt. be carfull
Dec 09, 2007 | GE Profile JGS968 Gas Kitchen Range
Tappan MGF500PBW Gas Kitchen Range Logo
180 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
