My remote is the Sharp LCDTV GA566WJSA and I cant find a way to turn the CC on. There is no opening or flap. it just isn't there and the menu doesn't give me an option to turn it on, just to make the writing larger or change the font
SOURCE: Sharp Aquos LCD TV 52"
Its in the TV Setup. The Cable box will output the Closed Captioning on
Line 20 or 21 of the Picture - this is just at the top of the TV
Picture where you can't see it. The TV Menu should have a choice of
closed Captioning like CC1, Teletext, etc. and one of them should be
selected. After exiting the menu, you should start seeing Closed
Captioning
on the tv.
SOURCE: no remote how to turn off cc
You might try a Magnavox brand universal remote. Get one with a "menu" button. Often they give nearly complete control on a Magnavox brand TV. Otherwise, the only real solution is to purchase the exact original remote. There are many vendors on the Internet selling replacements, but often the costs are ridiculous.
SOURCE: Need the code for philips universal remote CL034
Here are the codes.
SHARP.... 0509 0913 0907 0603 0002
....... 0502 0224 0228 0202 0111 0813
You can get the manual here on link below.
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/1500115_AD_EN.pdf
SOURCE: Turning off Closed Caption
Are you using a cable/satellite box or just basic cable service?
When you go to the menu what options become available to you?
If the following options are present-
smartlock
setup
cc
If not try to press both the volume buttons on the front of the TV at the same time and see if the above options become available.
If so use the channel down button on the front of the tv to scroll to "cc"
Once CC is highlighted use the volume + button until it says CC off.
If these menu options don't become available please reply what options are shown.
Good Luck.
