Question about Ricoh Aficio 2020 All-In-One Laser Printer
Remove paper from adf error ricoh aficio 2020
Aficio 2020 says remove paper from adf when there is no paper... no paper pieces and sensor seems to be freeley going up and down
is there a way to reset the whole unit or something???
  • Ricoh Master
  • 1,297 Answers
Clean the paper sensors and move the actuators.Open and close front door to reset malfunction.
Posted on Jul 31, 2009
Hello, Our Ricoh Aficio 2000 is saying to remove paper from the ADF but as far as i can see there is no Paper. Tried switching it on and off again but to no avail. Any suggestions?
Hello!
Swithing off and on do not solve your problem.
Make sure that you do not have any sort of paper in the ADF.
If you are sure that you do not have any paper, you probably have a faulty paper sensor.
Not the best help i know...
Jun 24, 2011 | Ricoh Aficio MP 2000 Black and White...
I need aficio af 2020 software and driver to download
To download the driver for Ricoh Aficio 2020 follow these .steps :
1. Go to the link below
Driver download for Ricoh Aficio 2020
2. Select your operating system from the given list.
3. Download the required driver software.
Nov 17, 2010 | Ricoh Aficio 2020 All-In-One Laser Printer
I am Engr Desmond O,i am working on Ricoh 1035 and when is picking from the ADF and it will jam on the glass but i have clean the sensor, picking roller and the glass but till jamming paper, please what...
Im not going to explain in fine detail .It sounds like you do know what is going on.But if you open the 2 side covers and the top door on the ADF wou wil be able to remove the the white plate under the white plate is a nother sensor.If you did that then replace that sensor it can be faulty.
Aug 10, 2010 | Ricoh Aficio 1035 Copier
When use adf with letter paper sise, push print botton then askme paper 5 1/2 X 8 1/2 inch´s, why do this?
is there any sensors on the adf unit, if so is the paper being feed into the adf unit, there might be a bad/defective sensor, try placing a letter size sheet on the document glass and make a copy, if it copies you have a problem with the adf, and it needs to be serviced
Feb 19, 2010 | Ricoh Aficio 2018D All-In-One Laser...
Ricoh Aficio 2020 All-In-One - printer offline
Under printer check book unmark Use printer offline
Nov 23, 2009 | Ricoh Aficio 2020 All-In-One Laser Printer
ADF error
Hello sir; Make sure there have no paper chips in the paper path, then turn power off and back on, if still have problem, then check the paper sensor is moving freely.
Apr 28, 2009 | Ricoh Aficio 2020 All-In-One Laser Printer
Ricoh Aficio MP 2000 ADF (auto document feeder) is not working
tape is on the underside of the ADF causing a sensor to not tell the machine that the ADF is in the lowered position. look under where the hinge area goodluck
Apr 22, 2009 | Ricoh Office Equipment & Supplies
Ricoh AP3800C "Output tray full"
Check the little black piece of plastic that senses the printed page exiting the machine. Our sensor was stuck and I was getting the same message (an similar Ricoh product). When I gently reset the black piece to center, moving freely, printing worked again. I think the sensor got jammed up when we were trying to remove a bad paper misfeed.
Ricoh manuals very confusing on this error message. They refer to standard tray, tray one, etc. without being clear whether it's a paper feed tray or the so-called "standard OUTPUT tray." The output is not really a tray, it's just the depression where your sheet lands after printing. I wrenched on the paper feed trays and their settings for an hour before I figured out they meant OUTPUT.
Feb 27, 2009 | Ricoh Aficio AP3800C Laser Printer
RICOH Aficio 150 Paper Jam Reset
There is not a reset for jams in service mode. Did you open and close all the doors and make sure they are closed all the way. Most likely you still have a small piece of paper left some where in the paper path or you may have a broken sensor flag.
Jan 24, 2009 | Ricoh Aficio 150 Copier
Ricoh Aficio 2020 All-In-One Laser Printer Logo
778 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
