Question about Vacuums
Beater Bar works off and on
The Vacuum runs, but the beater bar works off and on. It acts as if there is a short somewhere.
  • wlrprr Aug 01, 2009
    When you put the button on the handle to the vaccuum cleaner to "carpet" to clean the carpet the vacuum will be on, but the beater bar only works part of the time. It will be on for a 1-2 seconds, then off for 1-2 seconds. It seem to work better when you move forward on the carpet and tend to off when you move back. It acts as if there is a short somewhere. Since the vacuum works I am assuming this is something in the handle. This is a cannister vaccumm cleaner.
  • ThinkVacuums
    ThinkVacuums May 11, 2010
    What settings are you putting your vacuum on when you use it? What kind of surfaces are you cleaning?
  • 97 Answers
If all the settings are correct, then try to replace your belt(s). if you look at them, they will look fine. in reality the belt can stretch and the brush will not work as it should. Fyi : belts need to be replaced approx. 6-8 months reguardless of the way they look.
Posted on Aug 02, 2009
My Dyson vaccum leaves a row of multiple lines on my plush carpet. I've never had s vaccum leave more than the two wheel lines. I called customer service and they had no solution for me!
It's the beater bar brush. Turn it over and use a screwdriver or knife, and run it the full width of the beater bar to remove the hair and string and other debris that get wound up on the beater bar-NOTE you do NOT have to remove the beater bar or take apart anything. As long as the beater bar spins, and there are no missing sections on the beater bar- this will work. Beater bar could also be worn down- be sure that the bristles extend past the bottom of the vacuum- ALWAYS DO THIS WITH THE POWER OFF
May 03, 2017 | Dyson Vacuums
Beater bar only spins when vacuum is locked & upright.
Your belt is probably stretched and can't turn the brush when it's on the floor. Replace the belt at least twice per year.
Feb 23, 2016 | Bissell Pet Hair Eraser Bagless Vacuum
I was told by a previous repair man that there is a fuse in the beater bar that needed to be replaced.
Up to my experience in my Panasonic vacuum cleaner, if the beater bar is not working this could be because the 'Carpet/Floor' selector switch is in the 'OFF' or 'FLOOR' position. In both of these positions the beater bar will not rotate. Move the selector switch to the 'CARPET' position. When in this position the beater bar will rotate once the foot pedal is pressed.
If the selector switch is in the 'CARPET' position and the beater bar is still not rotating it could be that there is something entangled in the beater bar, or the belt is worn or broken.
To check this first unplug the vacuum cleaner
Inspect the beater bar and belts to ensure that there is nothing entangled in the beater bar and that the belts are intact and are not excessively worn. If the belts are excessively worn they may slip resulting in the beater bar not rotating.
The vacuum cleaners often have an overload protection system inside the nozzle, which stops the nozzle motor when the beater bar jams to prevent belt breakage. After clearing any lint build up or jamming you may need to reset the overload protection, by pressing the reset button on the top of the floor nozzle.
May 04, 2015 | Vacuums
Belt replacement
It's a fairly simple job. The belt just loops over the end of the beater bar and motor shaft. Need to take the cover off the beater bar housing to get to it. Most difficult part is stretching the belt while putting the beater bar back in the housing.
Charlie
Aug 30, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
It has no suction...last couple of times while using the vacuum it would cut itself off. If I tried to use it the next day it would do the same thing
You vacuum is probably plugged up. Flip it over, beater bar up, and remove the plate that surrounds the beater bar. The beater bar needs to come out next. If the belt is good, it will be a little hard to remove. The beater bar sits in sockets that then go ilto the vacuum frame, so note how they come out as you ease the beater bar out and slip the belt off of the bar. There's a cavity behind the beater bar where the vacuum picks up debris. Stuff hangs up there, and you'll need to remove whatever is plugging you up. While you have everything open, give it a general cleaning. Remove anything wound around the beater bar, etc., and reassemble the vacuum in the reverse order.
Best regards --W/D-- -- please feel free to rate this solution - thanx!
Aug 04, 2009 | Vacuums
Low suction
Hi, You can take care of both things at once. Here's how:
Unplug and flip your vacuum over, beater bar side up. Remove the cover base plate that surrounds your beater bar. It's held on with either clips or screws, and usually "hinges" toward the front of the vacuum to release when the clips/screws are undone. Remove the base plate. The beater bar sits in sockets where it fits into the vacuum. Pay particular attention to how it comes out as you remove the beater bar, so it will be much easier to put it back together. If your belt is good, it will want to come off with the beater bar, but will remain attached to the motor. If necessary, slip the belt off of the beater bar. Behind the beater bar, you'll see a cavity. This is where the vacuum pulls the dirt from the beater bar. Look up into the cavity; stuff almost always hangs up in there. Remove any debris that you can find. While you have your beater bar out, look at the ends, where it fits into the sockets. Hair and other material catches on the beater bar and winds around it. If it is in and around the sockets, it causes the vacuum to have to work harder to clean. Remove any debris that you find on either end. Get your new belt and place it on the motor shaft. Slip the beater bar into the belt, and install the beater bar and sockets back into the vacuum frame. It takes patience so don't worry if it takes a few tries to get it right. Once in, test your work by revolving the beater bar a bit with your hand. You should be able to feel the tension of the belt as it turns the bar and the motor shaft. Take one more look at the sockets, just to be sure that they are in the proper place, and that the beater bar is level in the frame. Reinstall the base plate. This should have you finished at this end.
Best regards, --W/D-- please feel free to rate this solution! Thanx!
Aug 01, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
How do I change the belt on the motor?
Hi. This is easily done. Flip the vacuum over, beater bar up. With the machine unplugged, locate the screws or tabs that hold the base plate on, surrounding the beater bar. Remove the plate. The beater bar is held in place by fitting into sockets that then fit into the vacuum frame, so be careful in removing the beater bar. Pay close attention to the sockets, so you can get the bar assembly back in easily. Replace the belt. When you fit it over the motor shaft, you'll have to slip the belt onto the beater bar, and fit the bar into the frame at the same time. Reinstall the plate, and test your work by revolving the beater brush a bit by hand......If you're satisfied, you should be good to go!
Jul 30, 2009 | Hoover U6630-900 WindTunnel Bagless...
Belt
Hi. This isn't a hard repair at all.... Unplug your vacuum. Turn the vacuum beater bar side up. Locate the catches or screws that hold the plate on that covers the beater bar. Remove the plate. The beater bar sits in sockets where it attaches to the vacuum, so remove carefully, making note how it comes out. This will make reassembly much easier. Place your new belt on the motor shaft, then onto the beater bar while you replace the beater bar back into the sockets. Test your work by revolving the beater bar a bit by hand. Reinstall the cover plate. That's it!
Regards! --W/D--
Jul 17, 2009 | Bissell 6594 PowerForce Bagless Upright...
HOW DO YOU CHANGE THE BELT ON A DIRT DEVIL VISION VACUUM CLEANER?
With the vacuum unplugged, turn the machine beater bar side up. Locate the clips or screws that hold the plate over the beater bar and remove the plate. The beater bar sits in sockets just inside. Be careful in removing it; take your time and note how it comes out...this will make reassembly easier. Clean the debris while you have tha bar off and remove any debris thet you see in the vacuum hose area behind the bar....The new belt slips over the motor shaft behind the beater bar (further up in the cavity behind the b/b), then you slip it back onto the beater bar as you place the bar back nto the sockets. Test your work by revolving the bar a bit to make sure that everything is back in place. Replace the plate.
Regards,
--W/D--
Jul 12, 2009 | Dirt Devil M088910 Swivel Glide Vision...
Vacuum turns on and suction in hose works, beater bar won't turn
If you hear the motor in the head running and the beater bar isn't rotating, you probably need a drive belt. With the power off, make sure you can rotate the beater bar freely by hand, if it isn't bound up.. then locate and remove the baseplate screws to gain access to the beater bar itself, you'll see a drive belt pulley system and chances are, a broken belt. Replace it with a new one by pulling the beater bar assembly out of the housing and plcing the belt onto the motor shaft pulley as well as the beater bar pulley.. nest the beater bar back into the holder and reinstall the cover. Hope that helps !
Aug 14, 2008 | Eureka Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
