There is power going into my acer extensa 5200 laptop but when i turn it on the screen it is black nothing else there
  • Michael Beverlin May 11, 2010
    Try hooking up headphones or listening to the onboard speakers. If you hear you OS start up properly then you might have a bad screen. Does the black of the screen change colors?? There should still be a sort of lit up black when the screen is on but recieving no video signal. If the screen is black like its not even on then you could have a bad screen or broken connection somewhere. If it is a luminated black, and there is a difference, then it could be the video hardware or if its onboard video then the motherboard might be bad. Try hooking up a external monitor to the vga output on your laptop to help in troubleshooting your problem.
  • 374 Answers
  1. Take out your battery and the power button for about 60secs.
  2. Start the laptop using the Adapter [without the battery]
  3. Lighten up your laptop...remove any external device attached [printer,scanner,pen drives etc.].
  4. It could also be a RAM problem,try changing the RAM if you have two start with one and exchange them.
After that when the system starts you can do the system restore START--ALL PROGRAMS--ACCESSORIES--SYSTEM TOOLS--SYSTEM RESTORE to restore it back to an earlier date when laptop was ok. THEN LATER ON PUT THE BATTERY BACK IN.
  • Try restarting after an hour gap.
  • If this doesn't solve your problem call the company people.Their might be a Video Card problem or any other internal hardware problem.
Posted on Jul 31, 2009
  • 11,896 Answers
Most likely faulty power supply. Sometimes it can be the motherboard, but most times the power supply is bad.
My acer laptop extensa 5620 will not turn on,it is totally dead with no lights showing and no sound coming from the laptop, i have taken the battery out and plugged in the power cord and still nothing
My Laptop wont turn on [Solved] - CCM
ccm.net > Forum > Hardware > Laptop
Nov 13, 2015 - Hello,i need help.my acer extensa 5630ez wont turn on.i tried charging it for hours.it still wont turn on.when its plugged in, the battery led light ... My acer laptop wont start up!!! [Solved] - CCM
Jan 10, 2015
Connecting an external monitor to my Acer [Solved] - CCM
May 3, 2013
Mass storge controller acer extensa 5620 [Solved] - CCM.net
Apr 27, 2011
More results from ccm.net
Acer extensa won't boot. FIXED !! - YouTube
? 0:28
https://www.youtube.com/watch?v=Tb8hzSqWnjs
Apr 1, 2011 - Uploaded by Gen
Watch the fix i used here http://adf.ly/Pnk8u Acer extensa 5420won't boot. ... MADE THE LAPTOP HOT AND TURNED IT ON AND IT WORKED!
Acer Laptop Stops Powering Up- Wont Turn ON - Tech Support Forums ...
www.techimo.com > Forum > PC Hardware and Tech > Technical Support
Jun 5, 2010 - 11 posts - ‎3 authors
Dec 21, 2015 | Acer Extensa 5620 Notebook PC
Extensa 5200 user manual
Greetings-
Here is a link to the Acer 390 series laptop user manual.
http://dl.owneriq.net/d/d04f006b-b483-446b-9578-42ea9c934455.pdf
I hope this helps
Dec 14, 2010 | Acer Extensa 392C PC Notebook
Acer Extensa 4630. The screen is blank but the computer is running. The acer screen appears upon start up but then the screen turns black. Any suggestions?
have you enabled "standby"mode,you usually have an option when shutting down.Either this or go into settings and make sure you havent adjusted sleep mode for the screen
Sep 10, 2010 | Acer Extensa 4620 Notebook
Acer extensa 5420 black screen turned on but cant hear or nothing ok i turn on the laptop and its working fine and then just it goes to a black screen i tried to turn it off but it wont go off the screen...
If you have another monitor you can hook that up to the blue connector( VGA) This is usually on the side or on the back. If you get a picture then your internal video might be bad.
Mar 17, 2010 | Acer Extensa 5420-5687 Notebook
I want to install windows xp on my acer 4230
Hi shaikh_shaha
Can you get it to boot using any of the options it gives other than boot normally? If the blue screen is caused by hardware then installing xp will still present the problem. If the blue screen is an operating system crash then using the recovery disk or doing a repair install will solve the boot problem.
If you still rather install xp then you need to go into BIOS and set 1st boot device as CD. To go into BIOS you will need to press F10 or F2 (usually) as displayed on the splash screen when you power on
Does this help?
May 02, 2009 | Acer Extensa 4620 Notebook
Screen on my extensa 5630 laptop shows nothing but verticle lines
I had to finally send the machine to ACER and it was a hardware problem; they have to change the cable linking the display with the MB
Mar 22, 2009 | Acer Extensa 5630-6806 Notebook
Problm regardng lcd screen
turn it on and shine a torch onto the screen while it is black.
if you can see what is on the screen while doing this you will need to get a new backlight. these are not expensive, around £15. you will need a technician to install it for you though.
Feb 25, 2009 | Acer Extensa 4620 Notebook
My Screen wont work.
could be that it was somehow damaged and a wire lose
other causes are that the screen may be going
how old is this laptop
Jan 16, 2009 | Acer Extensa 4620 Notebook
Acer Extensa 5210 laptop wont boot
Try the following:
1) Remove power cord, battery and hold the power switch down for at least 30 seconds.
2) Remove and reinstall your memory module(s).
If those don't do it, get back to me for more ideas.
Thanks!
Ron
Dec 14, 2008 | Acer Computers & Internet
I Acer Extensa / AT&T usb wireless card
I had trouble too..  Go Verizon.. no trouble
Nov 24, 2008 | Acer Extensa 4620 Notebook
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
