Question about Pinnacle Dazzle DVD Recorder
Need more recording time - Pinnacle Dazzle DVD Recorder
  • 29 Answers
The "Capturing" time is limited (from my experience) only by the free space on your hard drive that is used for data storage. You can change this drive setting in the setups inside the studio software. You may want to refer to the Pinnacle User Forums on www.pinnaclesys.com they can be very helpful.
If you mean something else by your word "Recording" can you please specify what that might be ?
SD1
Posted on Aug 03, 2009
How to edit recording for extra time on program
You need to set your recorder for the longest expected time that the program will last. Unfortunately, you may be recording dead time if the game finishes early.
Apr 30, 2015 | Televison & Video
Changing recording time?
Hi and welcome to Fixyah,
If you won't allowed to enter the valid time record you need to go back to step number select video source and then try to click pull down arrow and then select your dazzle device, go back to step number 4 and then click on small circle and put the valid time recording.
Remember that the maximum time to record using DVD blank disc is only 103 mins.
Mar 09, 2010 | Pinnacle Dazzle DVD Recorder
When i click record it says insert a valid record time and i cant
if your IDVDR do not allowed you to input any minutes, You need to go back to step number 1 and then click on the pull down arrow and then look and choose Dazzle DVC 100 then go back to step number 4 and then go ahead and click on small circle and put the valid time to record.
Feb 06, 2010 | Pinnacle Dazzle DVD Recorder
Total recording time window won't work
I had this same issue when trying to record direct to DVD with 2.5, and could not solve it. Then, I finally ran through the wizard, and it indicated the maximum length for each level of video quality (DVD HQ, DVD LP, DVD SP, etc) - something to the effect of "At this quality, your device can record XXX minutes of video".
Once I set it to a quality level that exceeded the length I needed, I was able to proceed without any problem.
Sep 06, 2009 | Pinnacle Dazzle DVD Recorder
Is it possible to record one show, while watching another ??
You need to put a cable splitter on the cable. One side goes to the TV. The other side goes to the recorder. The output of the recorder goes to one of the alternate inputs on the TV. Set the recorder for whatever channel you want to record using its internal tuner. Use the TV tuner to watch a show live. Later, set the TV input to whatever you connected the recorder output to and watch your recording. You will probably need to do this to see the recorder menu to set up the recording.
Mar 10, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Need setup help for ep5962
first set day and time... menu, mailboxes, set day/time, scroll to day, set, select, ok... then scroll to current time, set, dial pad four digits, 2 for am or 7 for pm, select save. now power on line 1 or 2 or both. phone is preprogrammed with 'hello, please leave a message after the tone.' to record your own use menu, mailboxes, select setup 1 or 2, then review/chng oga, then record new oga, then ok. record when screen changes, choose stop when you're done. shortcut: press and hold record, press and release mailbox line x, release when finished. you only record one line at a time, so you can have different messages on each line. even if it's the same, you must record each line. since you can only record one message the shortcut would be useful for an 'out to lunch, be back about 1-30' sort of message. then re-record a standard message when you get back from lunch. 'course, you really don't need an 'out to lunch' message, since people are accustomed to answering machines at any time of day. all the caller needs to know is that 'i can't get to the phone right now.' and they appreciate it when you keep it short.
Mar 05, 2009 | AT&T EP5962 5.8 GHz Corded / Cordless...
T30 always comes up with record-ready display screen
T30 defaults to an opening display screen based on where you were when you last used the device. When leaving from the record folder and record mode, you will always open with the record-ready screen. If you left your T30 while in the music folder playing a music file, you will be returned to that.
This record-ready display screen has a numeric and bar time line. The numeric values of the line are in hrs:min:seconds. This line is also split: the right half of the line indicates the total amount of available recording time, while the left half indicates your time as you record. If you compare the values of the right and left sides of the numeric bar while you are recording, you will see that the right side is diminishing as the left side increases in numeric value. When you complete your recording and save your track, the right side will now indicate the new total time (the amount your screen first displayed LESS the time value of the track just recorded).
When you are playing a music file, if you watch the time display, you will see the numeric information changing in the same way. The left side indicates how may hrs:min:seconds your track has played while the right side indicates the total time value for that file and will be correspondingly decreasing while you play your music file.
So in the short, you don't need to worry much about your display screen unless you open in the wrong folder or you need more recording time than is available. Then it has a message for you.
Nov 06, 2008 | iRiver T30 MP3 Player
Help
1. Power ON the recorder, put a cassette tape into the slot. Select EXT 2 as source for the recording when you use an external device as source for the recording.
2.You will need to leave your cable/satellite boxON and tuned to the correct channel for proper recording to occur.
3.
Press z (RECORD) repeatedly to select the recording time length. The recording time can be extended anytime by pressing z (RECORD).
Here are the few possibilities to answer your question. Goodluck!!! let me know if this helps.. thanks
Jan 02, 2008 | Philips DVP3340V
This is suppose to hold hours of recording time and mine only holds a few minutes. How do I increase the time?????
Two things to try: make sure you have a big enough memory card for the intended format and recording time. I suspect you are trying to use the 16MB Compact Flash card that came in the box. A 1GB card will record much longer than the battery life in the Microtrack 24/96, even when recording 24-bit stereo in WAV format. If you have a smaller card, and want long recording times, use an MP3 format. Using the MP3 encoder, monophonic recording, 128K bits/sec, 44.1K samples/sec, you should be able to record over 16hrs of audio on a 1GB memory card. Same card, WAV encoder, 44.1K samples/sec, stereo, 24-bit audio will produce only a little over one hour of recording time. With the 64MB card that came with the recorder, the most you can record using WAV encoding, 24-bit audio, 44.1K samples/sec, is a little less than 4 minutes. With 16-bit audio about 6 min, and with mono and 16-bit audio about 12 min. With WAV, 24-bit audio, mono recording yields 7:52.
Nov 07, 2007 | M-Audio MicroTrack 24/96
Pinnacle Dazzle DVD Recorder Logo
381 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
 Ian Kayhan
Ian Kayhan
Pavel Pranovich
Pavel Pranovich
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
