SOURCE: i want to know if
If you have on screen menu go to your info menu and it should tell you if you your set supports 1080i or p resolution. If so you have an HD set.
SOURCE: What's the difference between a hisense smart TVs and a hisense smart led tv
LED Smart TV saves Power and Contrast & Colour you will get better than Smart TV.
SOURCE: How to program the netgear smart TV remote to a hisense 42' flat screen tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
SOURCE: My 50in LG smart TV has sound but picture is hardly seen on the screen, how can I fix this?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Bill, The 50H7GB's smart features are based on the Opera OS. Hisense uses an Opera-based platform for its connected features the same system/browser you'll find on Nintendo's DS and Wii video game systems.Check the attached links,instruction and guides, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Hisense H7GB2 4K Ultra HD Smart TV Review 50H7GB2 55H7B2 65H7B2
Hisense 50H7GB
Hisense The H7 4K Ultra HD TV
