Question about Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range
Oven door hinge adjustment...?
The oven door on my 4 year old dual fuel oven has gradulally closed with less and less force over time. In the beginning the door could be positioned at varying degrees of "openness" i.e. 1", or 2"  etc. now that is not possible. there does not seem to be a force being applied to the door to maintain the closure or make the seal.   losing oven and gaining a fire pit Bill
Re: Oven door hinge adjustment...?
Regarding the oven door not closing all the way and dropping suddernly to the floor, I called a local authorized service company and asked if there was a door spring (no). So the recommended solution is to have the hinges replaced. However, since the oven door didn't really hold its open position from the beginning, when it was brand new back in 01, I'm going to see if a new Viking oven has the same defect as ours. Then, it would seem like a good idea to take a chance on having it repaired.
Is replacing a set of oven door hinges something a person with reasonable mechanical aptitude can do?
Posted on Dec 05, 2007
How to get to the spring for the door on a Hotpoint range
Posted on Oct 24, 2008
  • 213 Answers
The springs on the hinges for most viking ranges can be adjusted but the door will have to come apart to do so. if yours can be adjusted the once the door is apart youll see a screw at the top of the spring in the door. just tighten the screw a few tunrns on each spring. if theres no screw then youll need to replace the hinges.
Posted on Nov 25, 2007
0 characters
3 Points
Oven door wont close properly chef gbc5266wng
Wow Must be a very old oven. The closes model number I can get is GBC26CK. But most hinges have no adjustment to them. They just need to be changed out.
Jul 23, 2012 | Kitchen Ranges
Door sags open when hot.
i just had this problem with a jenn air range i was repairing, installed new hinges door closed fine, heated oven hit 200 degrees and light came on (door opened slightly) as per techline I shimmed the hinge reciever to make a bit tighter. sure enough!!! been 3 weeks she hasnt called back yet (and trust me if it didnt work she would!.. call the tech back and have him call the tech line while in home
Mar 13, 2008 | Frigidaire PLCS389DC Dual Fuel (Electric...
Bosch HDS7282U oven door won't close properly.
I am a old bosch repairman and i know for a fact that the door can be fixed. tighten the hinges with 3-4 washer on both hinges. nyc can fix this problem . if your door is really bad then both hinges has to be changed. but sometimes the old hinges willdo the same after awhile.
Dec 20, 2009 | Bosch Evolution Pro-Style 700 HDS7282U...
Lofra five burner gas cooker, oven door not closing properly,
It sounds like you need to check the fixing screws of the oven,failing this replace the hinges.
I hope this helps.
Jul 07, 2009 | Lofra MXD96MFEPI Dual Fuel (Electric and...
Adjustment to door hinge, as door does not close completely
In most cases door hinges needs to be replace but some time with old stile ovens and ranges help this trik:
1. Put small towels on right and left hinge between the door and range/oven body
2. Close door and gently push like you try to close completely.
3. Try several times.
4. Open door, remove towels and see if it helps
5. If not replace hinges
Nov 29, 2008 | DeLonghi Kitchen Ranges
Frigidaire 40 inch range model #REG46NW-2
Mar 31, 2008 | Frigidaire PLCF489AC Dual Fuel (Electric...
New Cornu Fe Stove - Oven door pops open
I had the exact same issue with my Cornue Fe (only on the right hand side oven). The other symptom I noticed was that the door itself didn't close as smoothly as the left hand side oven.
Take a look at the alignment of the "post" sticking out from the oven relative to the spring loaded catch on the door. These need to be *very* well aligned vertically in order to keep the door closed as it heat cycles. You'll notice that the post has a depression at the end of it (furthest away from the door). The door catch has an upper and lower spring loaded roller that is supposed to "catch" on both sides of the depression. If you are misaligned vertically, then only one side of the catch will be applying sufficient force to the depression.
In my case, the post and the catch were misaligned by about 4-6mm. In fact, I noticed that repeated opening & closing of the door was actually causing some wear on the upper roller of the catch. To fix, I needed to raise the door, which was accomplished by adjusting the hinges.
I removed the door from the oven, which can be done by removing the screws on the hinges. The hinges consist of a bottom & top knob that slot into the door (similar to the way refrigerator hinges work). The hinges themselves are made of ~1/4" metal (could be stainless, but it's relatively soft stainless). I put the lower hinge in a vise (appropriate covering to prevent scratching) and *gently* bent it up to adjust the door upwards. Putting it back together required some help (the door is heavy), but after a bit of work it was all back. Thankfully the alignment was right the first time. This whole process took about 20 minutes.
In my case, I suspect that either the wife or kids had put too much weight on the door at some point and bent it out of alignment. The problematic door had about 4-6mm of "play" between the top and bottom hinges prior to my adjustment--the working door had zero "play". You might want to check to see if you have any such play before you do this work (you can either look at the hinge itself or simply lift up on the door at the hinge point to see if it moves). If you don't have this same play, but you do have misalignment, then you'll need to adjust both top and bottom hinges.
The other possiblity is that you might have a weak spring in the catch mechanism. You can check that by gently pushing a flat head screwdriver in between the two rollers and feeling for how much force is required to separate them.
Of course, you can also just call the La Cornue service folks and have them check it out.
Mar 21, 2008 | Kitchen Ranges
KDRP407HSS oven door adjustment
I found a solution. Remove door (very simple procedure listed in Use and Care Guide). Make a shim and attach it to the end of the hinge arm (the part of the hinge protruding from the door that goes into the slot in the frame). I used metal shears and a coffee can and made a metal strip that I wrapped around the arm 3-4 times. Reinstall door and it should be tight at the top. (Unfortunately I suspect this fix will be temporary until the ill-designed hinge mechanism starts bending again.)
Nov 12, 2007 | KitchenAid KDRP407HSS Dual Fuel (Electric...
Oven door just barely closes- light stays on
put a tea towel on both sides of the door [folded] down by the hinges then close door. gently push the door close try a few times with a little pressure.
Nov 12, 2007 | Kenmore 96422 / 96424 / 96429 Electric...
Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range Logo
6,525 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Barrett Palumbo
Barrett Palumbo
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
