Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Have new logic board and gears. No matter where door is it will go down a foot. reverse and go down a foot. Can't seem to adjust
    President:
  • 3,197 Answers
Make sure you put the black cup back on the end of the motor shaft and that it is pressed all the way on. Make sure the rpm sensor is plugged in. If neither of these are the issue then you probably did not have the motor shaft pushed all the way back when you tightened the coupler after replacing the worm gear. Loosen that coupler up and from the front of the motor (opposite end in which the coupler is on) push the shaft back as far as it will go. Hold it there while you tighten the coupler back up and then try it.
Posted on Jul 31, 2009
Garage door doesn't close properly
I too am having the same issue. I replaced my console control because my garage door was unresponsive and that fixed that issue. Now I have to hold the button down sometimes double tapping the button and then holding it down to close it. I believe the first place to check is the limit switch. Look at your owners manual or get online help in adjusting that. If that does not work you may need a new logic board. As far as the sensors go, one is a sender and one is a receiver. They have indicator lights and when they are aligned they light up. Check those first as a logic board is usually alot more expensive. Check ebay though as I did as there are plenty of good used parts available. Just get the numbers off of your logic board so you know what to look for as far as model number and date of manufacture. Good Luck.
May 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener will not work after gear replacement
From your description it sounds like you forgot to plug in the RPM sensor.
Mar 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
check the end shaft platic cap is installed and runs freely between the rpm sensors.. that might be ur problem..
Mar 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door Wont Close Craftsman 1/2 HP (1998)
What it is is the electric beams at the door are getting blinded buy the sun or out of line. They are the two black boxes on both sides of the door about a foot from the ground. Put a piece of card board in front of them not blocking the beam dut to block the sun. All that they are is safety beams for kids so they do not get hurt. If you have to move them to the top where the sun will not hit them. Sorry to say though you can not remove them all the way. Also make sure the lite on them is not blinking if so they are out of line.
Good Luck and Please Rate FixYa!
Mar 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Electrical problem with logic board or terminal block
do you see burn mark on board? Is so and unit is older than 15 years, buy new one.
Feb 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door wont close in cold weather
find force adjustment on logic board and turn clockwise A LITTLE to increase down force. Try to stop door. You do not want TOO MUCH FORCE as that is a SAFETY HAZARD.
Jan 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Installed new worm gear, but now i cant get the door down
Check to see if the 4 wire harness is hooked up from the limit assy.
Jan 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
My garage door only opens then 1ft then returns 1fts
The wire harness (4 wire) from the limit assy is not connected to the photo interupter board.
Jan 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
88 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
