Question about Panasonic Lumix DMC-FZ30 Digital Camera
Fz30 monitor I have problems after using one of these camers for about 6 months with the monitor not showing anything (goes black) in the normal up right position. We use these camera's everyday in my business and I have 4 of them now that I can't use because of this problem. Any thoughts/Al
  • kroni Dec 05, 2007
    My LCD monitor isn't all black but it turned all static.
    In the middle of using the camera taking pictures one moment it was all OK and then I just got a picture like on a TV with no aerial; just white static grizzle.
    The eye piece LCD is fine but it just isn't the same.
    Is there anything in the LCD driver of the camera that can just snap??
  • crippled Dec 07, 2007
    same problem here like kroni has. Maybe the flatcable is loose?
I opened the swivel LCD display and checked the cable there but it made no difference.
Either the cable is loose in the camera (which I am not sure how to open) or something in the electronics just went.
Has anybody had any contact with Panassonic because of this problem??
Posted on Dec 11, 2007
I use samsung netbook nc110, it works normally until I play a video and the screen goes black and won't come back to normal. I bought it 9 months ago and this begin happening last week. Any solutions?
You can use an external monitor to test it. If the external screen does not display anything, then your GPU and or motherboard is dying. If your netbook works good with the external monitor, then your screen is dead.
You can check the operating system and application using this Norton Utilities:
http://download.cnet.com/Norton-Utilities/3000-18512_4-10907620.html
Mar 09, 2014 | Samsung NC110A02 Netbook
Vaio LCD problem
Periods.......Nice little items because they denote the End of a sentence.
See how this works?
"I have a vgn cs36gj, I was working with it, suddenly the LCD became pale black, I connected it to external monitor and it has a picture, sometimes after turning on for 30 minutes LCD start working normally, but after turning off and disconnecting power when I turn it on, it only shows a pale black picture, you know it is on but only black!"
Now you try it.........
"I have a vgn cs36gj. I was working with it, suddenly the LCD became pale black.
I connected it to external monitor and it has a picture."
Okay, I got that part.........
"sometimes after turning on for 30 minutes LCD start working normally, but after turning off and disconnecting power when I turn it on, it only shows a pale black picture, you know it is on but only black!"
WHICH LCD?
Laptop LCD?
External monitor LCD?
Man on the moon LCD?
1) If the external monitor LCD goes 'pale black', the problem is the graphics chipset.
This I do not believe
2) If the laptop LCD goes pale black, this I believe.
Post back in a Comment.
Regards,
joecoolvette
Apr 25, 2013 | Computers & Internet
Lcd monitor goes black
Try a different monitor (a friend's) on your computer, if it works OK the problem may be with your monitor. If it does the same as on your monitor, the computer video card may be defective.
Try your monitor on a different computer (a friend's) etc. You will figure if anything or what is defective. Then you can decide to repair or replace.
May 31, 2009 | Apple Multiple Scan 1705 Monitor
The l226wtq goes black
Try shining a flashlight on the screen, or without the flashlight, try to see if you can distinguish anything on the screen at all, if you do, the backlight is dead, or the monitor has an internal most likely unfixable problem.
May 01, 2009 | Computers & Internet
Monitor goes black for a few seconds
Try swapping the monitor cable from the working monitor to the other video connection on your computer. Effectively reversing the connections to isolate whether your problem is the video card in your computer or the monitor itself. If you find the working monitor displaying similar symptoms, then check your video drivers and ensure that you have all power saving features, screen savers, etc... turned off.
Apr 06, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
Monitor goes to sleep after hackers attacked..
This is the way how to check what's wrong with your monitors. After you turned it on and the screen went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Mar 08, 2008 | SAMTRON 77V 17" CRT Monitor
Green Screen
There are seveal cause to this issue, but with out seeing what your seeing I recommend that you search youtube on this one.
https://www.youtube.com/watch?v=84HPv6Epknc
Mar 05, 2017 | Dell E156FP 15" LCD Monitor
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Panasonic Lumix DMC-FZ30 Digital Camera Logo
66 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
