Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Starts but when throttled it dies. Will idle all day at idle.
I have replaced the carburetor, spark plug, reset the coil gap. I also removed the cylinder head and checked piston and rings, also removed the sump for seal problems and found nothing. I reassembled the unit and nothing changed.
I'm kinda thinking it may be the coil. It kinda looks like it's not advancing the spark as needed for higher speeds. This saw has me stumped.
    Novelist:
  • 168 Answers
After repairing saws for 30 plus years, this one didn't make much sense to me. It's the second time only since CDI ignitions came in that i had to replace the module. I guess it must drive the high speed timing out of wack.
Anyhow, replace the module and unit runs well.
Posted on Aug 02, 2009
Testimonial: "Good choice."
    Scholar:
  • 173 Answers
It may be a faulty coil, but if you haven't tried it yet, I would be inclined to play with the settings of the plug.
Maybe a combination of adjusting the plug, and the gap between the contact and the magneto. If that doesn't do it, change the 'cheaper' contact first.
If problems Still persist, you may have to change the magneto.
Good luck with that, hope I've helped you.
Don't forget to rate ;) thanks
Posted on Aug 01, 2009
Troy-Bilt Hand-Held Blower dies when warm and throttle wide open
You reported that most of the items I would've suggested, you have checked...
Good job.
A couple more things:
  • Replace fuel filter, it's in the gas tank
  • Check and clean the Spark Arrestor screen at muffler, when they plug up, it's a major restriction to exhaust gas flow
  • And check and adjust High/Low screws at carburetor, video attached.
  • And clean or install rebuild kit for carburetor
Good luck...
One more...
May 30, 2015 | Troy-Bilt Garden
Throttle want throttle engine
Hi Mike, and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap to close or to wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discharged.
6. Damaged wire or loose connections at battery terminals,
ignition coil, or plug between ignition sensor and module.
7. Intermittent short circuit due to damaged wire insulation.
8. Water or dirt in fuel system, carburetor or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor.
12. Loose or dirty ignition module connector at crankcase.
13. Faulty MAP, CKP, and or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damage intake or exhaust vale.
As for the fuel valve leak they make a rebuild it for it. Good luck
Mar 21, 2014 | 1993 Harley Davidson FLSTF Fat boy
Idles fine but will not rev
Hi, Anonymous and the usual suspects are:
2. Spark plug cables in bad condition and leaking.
3. Spark plug gap too close or too wide.
4. Faulty ignition coil, module, and or sensor.
6. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
7. Intake air leak.
8. Water, dirt, or rust in the fuel system, carburetor and/or filter.
12. Loose, dirty, or corroded ignition module connector at crankcase.
13. Faulty MAP, CKP, O2, and/or CMP sensors.
16. Damaged intake or exhaust valve.
For more information about your issue and free downloads that you will need please visit the websites below, and for specific information or questions, please feel free to contact me at xlch@mail.com. Good luck and have nice a day.
Bike idles perfect but dies when given the slightest amount of throttle 93...
http://badweatherbikers.com/buell/messages/3842/143909.html http://buellmods.com/content/downloads/manuals/xbslightning/2004_lightning_manual.pdf
TWIN Motorcycles Buell parts
Buell Motorcycle Owners Manuals
Nov 23, 2013 | Buell Motorcycles
1994 HD 883 runs at idle but when your riding it surges then dies... But when it sits in idle sounds great and starts right up
Hi Anonymous, and the usual suspects are:
Good luck
Aug 05, 2013 | 2000 Harley Davidson XL 1200 S Sportster...
I have a yamaha 1981 pasola scooter and i sometimes starts but sometiimes doesnt. i.bought a ignition coil but it not that. what is the lil blak box that the coil wire connects to? cos thats the problem...
Instructions
  1. Spark Plug and Sensors
    • 1 Park the motorcycle on its center stand. Remove the spark plug-wire cap from the plug by hand. Loosen and remove the spark plug from the cylinder head with a spark plug wrench.
    • 2 Gap the spark plug to 0.026 inches with a spark plug gap gauge. Reinstall the plug tightly in the cylinder head with the plug wrench. Reattach the plug-wire cap by hand.
    • 3 Detach the wire lead at the fuel sensor on the right side of the cylinder head by hand. Loosen and remove the sensor with a metric wrench. Clean the inner end of the sensor with spray cleaner. Reinstall the sensor securely with the wrench. Reattach the wire lead.
    • 4 Detach the wire lead at the exhaust sensor at the underside of the muffler by hand. Loosen and remove the sensor with the metric wrench. Clean the inner end of the sensor with spray cleaner and reinstall the sensor securely. Reattach the wire lead.
    Throttle and Carburetor
    • 5 Take a position where you can observe the throttle linkage at the left side of the carburetor. Twist the throttle grip at the handlebars slowly as you observe the action of the linkage.
    • 6 Tighten the cable adjuster at the top of the carburetor with a metric wrench in small increments so the linkage responds immediately as you open the throttle.
    • 7 Start the engine and allow it to warm up for three minutes. Locate the smaller idle-adjustment screw and the larger fuel-air adjustment screw at the right side of the carburetor. Turn the idle-adjustment screw to the right one full turn with a screwdriver.
    • 8 Turn the fuel-air adjustment screw to the right or left with a screwdriver as you listen to the engine's speed. Turning it too far either way slows the engine's speed. Find the point where the engine idles at the fastest speed.
    • 9 Allow the engine to idle. Turn the idle-adjustment screw to the left one full turn.
Jan 14, 2013 | Motorcycles
Cant get my 03 wideglide to idle at lower rpm,bike dies down when lowering idle screw
6. Damaged wire or loose connections at battery terminals especially the ground cable at BOTH ends, ignition coil, or plug between ignition sensor and module.
11. Damaged carburetor or intake seals.
16. Damage intake or exhaust valve.
For a prime suspect please visit website below and good luck:
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Mar 23, 2012 | 2003 Harley Davidson FXDWG Dyna Wide Glide
Runs good for a couple minutes after starting, then at idle a small miss begins to occur, it increases and it stalls. this sook was running perfectly at 55mph and it died, no fire,after a few minutes it...
Hi Olddog6, and the usual suspects are:
6. Damaged wire or loose/broken connections at battery terminals/cables, especially the "NEGATIVE" cable at both ends, ignition coil, or plug between ignition sensor and module.
7. Intake air leak.
13. Faulty MAP, CKP, and/or CMP sensors.
For more specific information about your issue, please visit the websites below or contact me at xlch@mail.com. Good luck and have nice day.
2007 Suzuki Motorcycle Service Repair Workshop Manuals
Oct 10, 2011 | 2007 Suzuki DR-Z 400 SM
The engine has been sitting for a year, I have checked the distributor cap, the coil is new, and I have the Resistors, the spark plugs have spark, there is compression and engine will start but will not...
It sounds like a carburetor problem. If you send me the engine info, such as make, model, and year I can give more precise instructions on how to remove and rebuild or replace the carb. I hope this helps, please rate this, thank you
Mar 18, 2010 | Boating
I can not get my Poulan p4018wt started
Remove the spark plug and look at the inside porcelain--if it is wet with fuel, put the wire back on, lay the base of the plug on engine metal, and pull the starter through while watching for spark. If no spark, try another plug. If still no spark, then something is wrong with the ignition system. Gain access to the ignition coil. Remove the small wire that connects to the coil and try the starter again. If now sparks, the stop switch is probably defective. If still no spark, replace the ignition module. Use card stock to set the clearance between the module poles and the flywheel magnets. Try the starter again--you should have spark by now. Put everything back together and try to start the engine.
If the plug was not wet in the first check and it does spark, then you have fuel problems. Make sure you have fresh fuel in the tank. Check the condition of the fuel line from tank to carburetor. Remove the carburetor and disassemble. If the rubber diaphragm is stiff and cracked, re-kit the carburetor. While it is apart, use spray carburetor cleaner and wash out everything that is metal--don't wash anything rubber or plastic. Blow out all passages with compressed air. Turn both jet screws (H and L) in CW to stops (lightly), then back out CCW 1-1/2 turns each. This should get the saw running. Start with H needle (after engine warms up)--open throttle full speed and turn needle CW until highest speed is reached, but 4-stroking. Engine should immediately smooth out when cutting lightly. Next, run at idle and adjust L needle for smooth idle, but rich enough to allow engine to follow the throttle without gasping. Set idle speed low enough that the chain stops turning.
Hope this gets you running.
Aug 12, 2009 | Garden
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
289 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
