Question about Canon Pixma iX5000 InkJet Plotter Printer
The printer does not feed the paper right and it other jams it or lets it through half way and then stops. A pop up window appears stating that there is a paper jam.
    Problem Solver:
  • 5 Answers
The Roller of the printer have problem. Please go to the nearest canon service center and change the roller for avoid the paper jam problem.
Posted on Jul 31, 2009
Paper feed issues when there is no Paper jam. All the rollers move when the printer tries to feed paper. It'll feed about and inch and a half of paper and then stop showing a Paper Jam.
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 19, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Minolta DiAlta model 151f, when i try to use the automatic paper feed on the top of the machine the paper goes in about half way then stops then a message comes caution original doc jam
Try cleaning the pickup wheels that pull the paper into the feeder. There might be an electrical sensor problem also that is not sensing the right paper size. So lets start with cleaning the feeder
Jan 04, 2010 | Minolta Office Equipment & Supplies
Paper Jam/Stall - no paper jam
Well what you need to do is do a rest on the printer.That should solve the problem.If you want any further support, an online technician from techbuddies can help you for free.For this log on to http://tinyurl.com/m7ghqz
Jun 18, 2009 | HP Photosmart C4580 All-in-One InkJet...
Paper Jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 11, 2009 | HP DeskJet 5550 InkJet Printer
Brother hl-2070n; Paper jams half way through drum unit.
Usually there is a sensor right before the paper enters the fuser. If the paper sensor is bad the machine will stop feeding and output the error paper jam. This is probably the cuase if the paper stops in the same position all the time.
Nov 19, 2008 | Brother HL-2070N Laser Printer
Paper jamming
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Oct 13, 2008 | HP Photosmart 2575 All-In-One InkJet...
Papaer will not feed
High ITConsult And MarkoP
The high pitched whine and the paper stopping just before the fuser (the hot) unit is a known issue on the C3000 and C4100. If you are still searching for the solution to this issue, let me know, as I now have a working fix for the problem.
Reply to this post for further info.
Jul 10, 2008 | Epson AcuLaser C3000 Printer
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
Paper jam light is on
Hi! I have the same issue. The only solution I still use: select print from document with no paper in the hp's feeder. Let the printer go on "paper out" message, now put the paper into the feeder and press the print button on the printer. Success!
Oct 05, 2007 | HP Photosmart 7450 InkJet Printer
Canon Pixma iX5000 InkJet Plotter Printer Logo
146 people viewed this question
old marine
old marine
