There are thin vertical lines running from top to bottom. Even in the splash screen. They're in groups of 3 with a wider space between each group. Any solutions? Thank you, Dan
Hi Dan
The only way to get rid of this is to either have the Mianboard repaired or replaced.
If the Projector is stil under warranty - it will cover it.
If not - It is quite expensive !
Hope this helps you.
If your getting color lines,replace your component cable if your are using them. that worked for me
lines running down screen
