SOURCE: can't uninstall microtek 5900 scanner
This is a funny problem. Try & locate SCanwizard 5 files and delete them. Complete the registry deletion as suggested. Run scandisk. Install and uninstall Scanwizard 5.
SOURCE: how to scan using a sharp mx3501n?
as long as your machine has been configured within the network settings. press the image send key then addres book then enter your email or select the folder or email addres to send it to.
SOURCE: Computers cannot find the Sharp Scanner on the network
Are you using Sharpdesk? first check the firewalls, allow the exception, if that is not it, then from network scanner tool profiles, Change the Port, I believe it defaults to port 4687 - or 4689? (this uses an FTP port,) Allow this port in the exceptions. If the network scanner tool is not running, your machine will not communicate with the PC.
SOURCE: after auto scan, channels are not being displayed
Yes try factory reset if still not working make sure in the country
If you forgot your computer password
During the boot up process you will see on the screen press delete to enter set up
Press either delete or f2 during the boot up process to enter BIOS scroll down to set user password you can change or remove your password from there
hope this helps
