2002 GMC Sierre Crewcab 4x4 Duramax Diesel A/C problem on 2003 duramax, air blower blows but air is not always cold. Often starts blowing cold air but the air gets gradually warmer as if AC is not on. I can actually turn AC off and circulate air in cab and get cooler air that way. It has been checked by gauge to have plenty of coolant.... any suggestions for testing compressor or another part?
  • 25 Answers
Ok now you said,the system was checked to be sure the refrigerant level was full . It could also be over full causing a over preasure shutdown. The compressor has a low and high pressure switch, that will disengage the compressor clutch if it senses a over or under preasure situation to protect the system.Did you check to see if the compressor clutch was Engaging and will it stay Engaged or disengage and keep cycling like that? you Will need to get the preasures on the high and low side of the compressor from a gauge manafold set and please record the outside temp. it will change the preasures in the a/c system than i can better help with the issue you have. also a/c will always work better if recirculated air is used, because it is already cooler than out side super heated air.
my name is ron and if you get the preasures for me i will be glad to check the preasures to My R-134 refrence card
Posted on Jul 31, 2009
2002 chevy 6.6 duramax wont start even in warm weather or after motor is warm..... only starts with starting fluid. codes are p0335/p0193/poo87/p0090
The Duramax fuel filter assembly is bad about sucking air. Replace the fuel filter assembly. It comes with a new fuel filter.
I need some good feedback.
Oct 09, 2011 | 2002 Chevrolet Silverado 2500HD
2002 duramax smokes at stop sometimes ,also blows some only when taking off. doesn't use oil.
if this is a diesel motor nothing is wrong this is normal for a diesel
if it not a diesel what color smoke is it blowing???
Nov 14, 2010 | 2002 Chevrolet Silverado 2500HD
Excessive black exhaust on 2003 GMC Sierra Duramax Diesel.
This is what i would try (cheapest first) redexe/wyyns
injector cleaner,double dose,then i have put 1gal gas in 10gal diesel to increase burn temp (you may encounter a hot start problem temporarilly)then if still smoking, get a compresion check on the engine(this will tell you volumes)
by the way the NATO tanks put in 1/3 gas in diesel to stop it freezing in arctic conditions.any more than 1/3 can result in problems.
Mar 17, 2010 | 2003 GMC Sierra
2002 chevy hd duramax 4x4
Sounds like the PRNDL switch on the side of the transmission. Be sure and clear the code before trying to start after replacing it.
Jan 23, 2010 | 1999 Chevrolet Silverado 1500
Holes in the transfer case of a 2002 gmc duramax
well there are a few options, depending on the wear of your transfercase you can just replace the rear housing and install new pump clips from gm, jb weld and other bonding agents will not fix the problem but rather prolong it, I just pick up a reman this week for my own truck that was only$1100 great deal compared to junkyards
Sep 24, 2009 | 2002 GMC Sierra
A/c does not blow cold air
ac needs recharged possible leak
May 21, 2009 | 2002 Dodge Ram 3500 Truck
2003 gmc sierra duramax 2500
Problem with Diesel Fuel System. Gmc 2002 duramax 2500 HD 4x4 will start
Apr 19, 2009 | 2003 GMC Sierra
Heating & Cooling Logo
238 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
