Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
It isn't letting me transfer files that are larger than 5 gigs to my WD external HD. Says not enough space. How do I make it so I can transfer them?
  • 30 Answers
Check to see what file structure the drive is formatted as. It's possible that it's formatted as FAT32 instead of NTFS. If that's the case, backup your data from the drive, reformat, and then you can transfer the data back to the drive.
Posted on Jul 31, 2009
Get full full capacity of external 2 tera Seagate that now is reaing only 110 gig
This has happened to me before, also. What I had done was copy a disc IMAGE from the old, smaller drive to the larger drive - and the larger one turned into the same size! You did not mention your operating system (Windows, Mac, etc) but my solution was in Windows to go to Disk Management function and view the unallocated space left. Sure enough, there was "unclaimed/unused" space for the entire difference in size. Following the instructions of the Disk Management tool, I just added the remaining space to what was C: drive. I could have just as easily created a different drive space with the leftover, it's up to you - but I find it preferable to have my space in one chunk.
Note: This is a very sensitive area of Windows when you're dealing with file systems. A raw beginner might want to have an experienced friend help them through it, but if you follow instructions EXACTLY even a first-timer should be able to do it. If this solution does not work, let us know. Best wishes - Mark
https://www.lifewire.com/how-to-open-disk-management-2626080
How To Open Disk Management
Oct 19, 2016 | Seagate Computers & Internet
Please help me ... how can i transfer videos from my Sony HDR-FX1000E Camcorder tape to save it into my laptop (SonyVPCEB1M1E)? i will be waiting to hear from you... thanks a lot.
Transferring video from your FX1000E should be quite simple using an HDMI cable. If you've recorded in HD, the files may be quite large, so make sure there's enough space on your HD to accommodate them or the transfer will error out (which might be the problem you're experiencing). Once transferred, the most recent version of Windows Media Player should be able to play them. You may want to convert them to MP4 files to save some space too. If space is an issue, think about getting a 1TB external hard drive to transfer them to. You can then plug both the FX1000E into your laptop and the external drive into your laptop at the same time and when capturing the footage save it directly to the external drive.
Dec 28, 2010 | Sony HDR-FX1000 Mini DV Camcorder
Cannot transfer files that are greater than 4GB
The lack of free space iis on your internal HD not the external. Whenever transferring files from one drive to another, you are acturally making a copy of the file to be transferred and sending the copy to the new drive. If your internal HD is nearly full, you can try to Cut and Paste the files to the external, or clear up more space on your internal b/4 tryiing to move the bigger files. Best of luck.
Greg
Jul 09, 2009 | Western Digital 500GB My Book World...
Problem transfering large files to WD 2.5" Ext HD using Windows
might be split up into partitions, see how big your bios says it is, if you're using RAID0 that could be the problem.
Dec 18, 2008 | Computers & Internet
221 GB Free on MyBook - Error states not enough space for backup
It may be due to the file system.  If formated as FAT32 files larger than 4gb may not transfer.  Try reformatting as NTFS to fix the problem.
Sep 21, 2008 | Western Digital 250GB MyBook External USB...
Iomega 500 gb hard drive: large file transfers
The default format for the IOMega drive is FAT32. This format will work on all versions of Windows, as well as Mac OS9 and above. Unfortunately, FAT32 can't handle files larger than 4gigs. If you want to use larger files, you're going to have to remove all the files from your IOMega drive and use your computer to format it to NTFS (Windows 2000/XP/Vista) or HFS+ (Mac OS9/X).
Consult your owner's manual for specific details.
Sep 12, 2008 | Iomega (33654) Limited Edition 500 GB USB...
Memory loss
It seems to me that when the drive was partitioned, the whole thing was not partitioned. If using Windows XP you can go under the Control Panel, Administrative Tools, Computer Management and then Disk Management. You should be able to see the drive and if any unpartitioned space is available.
Sep 09, 2008 | Maxtor Hard Drive
External hard drive disk space
Hi
Is it showing the 300gig in the properties? if yes then try to copy with command mode,If again its given problem then u need to backup your data and format the drive, then try copying.I think it will work.
T.Boopathy
Aug 17, 2008 | Western Digital My Book Essential Edition...
Backup hard drive to an external hard drive
"what the error actually says is, you have either run out of space, or the backup file (.bkf) is too large for this disk. note: if the disk is formatted with FAT32, the maximum possible size for the backup file is limited to 4 gigs."
That error means that the FAT32 file system only allows 4GB files or smaller to be transfered. The chance that the backup file (.bkf) is larger than 4GB suggests that this file is causing your problems. You could try manually copying around that file (selecting all files from that folder except the large one) and see if that works.
Usually you will get many errors copying a drive directly as system files will be inaccessible and whatnot. Your best bet is to limit your copying to "C:\Program Files\" and "C:\Documents and Settings\", assuming you have Windows.
Dec 13, 2007 | IO Magic Corporation GigaBank (I250HD35)...
How to transfer
If u want fast transfer use this software:
http://rapidshare.com/files/67700211/WinHIIP.zip
if u want manually just COPY -PASTE TO WD
Nov 13, 2007 | Western Digital My Book Essential Edition...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
163 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
