Question about Mitsubishi MS24WN Air Conditioner
Mitsubishi Mini Split sytems fails to operature
I installed a Misubishi Dual Zone Mini Split System within my home by myself, last October. The system consists of: Outdoor Condensing Unit: MXZ30TN2 Indoor Unit 1: MSH17TN Indoor Unit 2: MSH09TW Because of my lengthy "to do" list and the cool summer here, there was no hurry to get this system into operation until just recently. Approximately 1 month ago I hired a Heating and AC specialist, he vaccuum tested the lines and opened the valves on the condensor unit to flood the lines with refridgerant... Upon testing, the unit worked great. I was very happy with it's performance.... Up until yesterday...... Upon arriving home from work, I noticed that it was warm in the house. Looked up at Indoor unit 1 and noted that it was flashing a diagnostic code - 6 consecutive flashes. Unfortunately, my documentation that I have does not contain a trouble shooting tree and no where could I find what the flash code represented.. So, went outside to the Condensing unit, I knew that it had a 2 digit display on it's controller PCB.... It read "5F", which stated that my Indoor unit 1 had either an open or shorted temp sensor... I have a very good understanding of thermisters and their operation. It is hard to imagine that this item would fail in such a short period of time.. Assured all power was off to the condensor unit as well as the indoor units. Got my multimeter out, placed it on "ohms" and measured both of the incoming sense lines that came into the Condensor unit. Both were open.. Was very suspicious of this result, so I went inside and measured both indoor units at the sense nodes. Again, measured open.. So was lead to believe that an amplified signal of some sort must be supplied to the outdoor condensing unit... I also noticed that there is J-tag header on the condensor units controller PCB, so I am assuming that there is a tool (data link adaptor) that can be used to interface with the processor and read fault history and or diagnostics..... Does this DLA and software exist for DIYers like myself? But, anyway here is my dilema - this system is out of warranty, cuz I bought it a few years ago, installed it last October and yet did not fire it up till just recently.. I am hoping that you may have a suggestion for me to try before I have to spend big dollars to have it serviced. Right now, none to happy. Spent several thousand dollars on this system, worked for 3 weeks than failed? Not good..
  • 614 Answers
I will contact you later today with diagnostic data. Russ
Posted on Aug 01, 2009
The control card is displaying error ch-01
PDF]SERVICE MANUAL R?410A Ductless Split System Air ...
dms.hvacpartners.com/docs/1011/Public/.../42108920400_ICP_26610.p...
421 01 9204 00 1/03/13. SERVICE MANUAL ... Consult local building codes and National Electrical Code. (NEC) for special ..... 18000 (5970-22350). Heating Capacity (Min. - Max). Btu/h. N/A ..... Error Messages Displayed Front Panel. S.
Oct 08, 2015 | LG 18000 BTU Dual Zone Mini-Split Heat...
Why does mitsubishi split system heats room 5 degrees hotter than setpoint on remote
It could be something as simple as 'solar gain' adding heat through glass facing the afternoon sun....or maybe the remote is not in a location that senses the average temperture within the room. Maybe the remote is located in a slight draft entering the room.
If the remote was kept above a computer tower, the opposite would be the case.... the heat from the tower would keep the control thinking its warmer in the room than it is. The result would be a much colder room.
Mar 10, 2015 | Mitsubishi MUZ-FE09NA-1 MSZ-FE09NA-8 Mr....
Squealing sound from our mini-split!
If it were a car I'd say something to do with the belt. Maybe check that out.
Jan 01, 2014 | Klimaire 24,000 Btu 18 SEER DC Inverter...
My new LG mini split 24,000 BTU unit is Freezing up on the small tube side. Not cooling properly. I thought freezing up (low on freon) but wouldnt it be on the larger tube. Is it running the fluid...
The larger tube is the return tube for the hot freon gas from the evaporator. The small tube is the cold freon after is has gone through the condenser where gas is condensed to a liquid when the heat is removed. So I would say your system is low on freon.
Jun 09, 2011 | LG LM-2430H2L 24000 BTU Heat and Cool Dual...
Misubishi split a c 2 tons green light blinking problems
Please write how many times blinking and with an interval. Depends upon it, we can give solution.
Normally, blinking 5 times means for drain motor malfunctioning. Check drainline, oif blocked clean it. If drain motor not working, replace it.
If blinking 2 times, Indoor room air thermistor defective replace.
Thanks.
Feb 18, 2011 | Mitsubishi MSZ-A15NA Split System Air...
LM-2430C2L 24000 BTU Cooling Only Dual Zone Mini Split Air Conditioner: Does LG makes AC which can cater two rooms at time...
Yes they Do they are called Dual Zone Units. At http://www.paylessminisplit.com they are very helpful if you call them they can answer alot of questions about many brands of mini split air conditioners.
May 16, 2010 | LG LM-2430C2L Cool Mini Split Air...
Retrofit newer Sanyo split AC system where old is installed
absolutly if you change refrigerants witch you prob would have to you may have to flush the linesets to cleen all the oil out but you should have no problems
Apr 08, 2010 | Sanyo Split System Air Conditioner
Mitsubishi Mr Slim mini split outdoor unit fan.
Check the capacitor. Rating must be within 90% of rated microfarads. If it is a dual capacitor test between C and FAN. Set your meter to read microfarads (uF).
Aug 13, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
I HAVE A ROOM 21X32 HIGH CEILING. WHAT IS THE BEST SPLIT HEATPUMP TO INSTALL.
I myself am a fan of ductless splits. I would recommend either Mitsubishi or Daikin
Jul 07, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Mini split AC's
they are excellent and very efficient sytems
i have a muti pass ductless in my home and swear by it so much i went to school for them
I am now a mitsubishi cert expert
and cannot sing the praisees high enouhg for the ductless systems
Jun 14, 2008 | GE Quiet-Aire Ductless Mini Split System...
Heating & Cooling Logo
1,000 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
