I've undone all the screw from the bottom, & straightened the metal tabs that lock it but something is still not letting the cover come off.
SOURCE: I am trying to take apart the toaster, but...
You need to remove the four rubber feet at the four corners, and that's where the screws are. Get a small flathead screwdriver and pry the rubber feet out of their sockets and you'll see small screws.
SOURCE: another problem comes up....
You definitely have a problem with the hold down circuit. You will need a DMM. If you don't have one they are fairly inexpensive now and with a little reading of the instructions you should be able to master their use. Look for a fusible resistor. It should be a small shiny canister, pointed on one end flat on the other, with metal leads on each end and inline on the wire to the hold down mechanism. Once you find this, with the DMM on resistance setting (continuity), check across the device. If the DMM says infinity, in other words it shows a 1 and the display never changes, this is your problem. Replace it with a new one. They protect the device from runaway heating and are set to open at predetermined temps. Replace it witht the same rated device. Available at most electronic stores. The rating should be in centigrade (such as 160, 180, ect). This should solve your problem. You cannot solder the thermal fuse in as solder will melt when the toaster gets hot. It must be crimped to the wire. Sounds like your almost there. Good luck.
SOURCE: bottom screw on handle loose
open the door and you will have to peel and pry apart door.It is abot a 1-2" frame around inside door.that peels off it just snaps in.
SOURCE: Wingman Contacts Dirty, Cannot Open Cover
The the ring with 5 like screws is just cover that can be gentle forced out with a flat screwdriver. Then comes off the power control and the rubber gasket. Finally the top cover comes out. Simple. coco13cos(Romania)
SOURCE: Flair S2220 Removed the four screws holding bottom
Pop out the two little rollers underneath, at the front. you will find two little screws holding it on. Unfortunately, I found after I broke it off!
