SOURCE: I accidentally removed the clock/weather
It's actually a pretty simple way to add widgets back to your home screen.
Long press a blank area of your home screen. A dialog box to Add to Home will appear. Select Widget, and then select Clock [HTC]. You will be able to select from 12 different HTC Clock widgets. Select the one you like, and then press the Select button. It will appear on your home screen as long as there is enough room for it. You can move the widget around by long pressing on the widget and sliding your finger to the desired location on the screen.
Good luck.
