SOURCE: which one is better to buy IR 5075 or IR 5065
The all above models are same with minor change for speed
You need model as your daily output requirement
All models are heavy duty.
you can select any one for upto 10,000 print or copy per day or for 20,000 & up print/copy select ir 5075
SOURCE: copier canon ir 5065 prolems with eror code e 000808-0002
The error code E808 is not listed in the imageRUNNER 5570 / 6570 Service Manual. The error code description should read:
E808-0001 The IH power supply input voltages are higher than the stipulated voltages.
E808-0002 The IH power supply input voltages are lower than the stipulated voltages.
The
remedy description for either code is to plug the machine into a wall
outlet with the correct voltage and replace the fixing heater power
supply.
