Question about Dynamode (HT809STP) Networking Hub
Configerations pleas sir how can I enter the configeration of my Dynamode Networking Hub thanks alot
  • 79 Answers
Re: configerations
Model? Most Hubs are not configurable, but this may not be the case with this one.
Posted on Nov 25, 2007
0 characters
3 Points
Power light flashing but no connections flashing. although the pc and server connect when joined directly to one another.
Open the switch case and replace 2 capacitors (on power supply module) of 2200 mf /10 volt to 2200mf / 16 volt.
Sep 01, 2011 | Dynamode (SW240010-R) Networking Switch
All the lights flash steadily when plugged in with or without any connections,
Try disconnect the power and then reconnect after a while. If it's a manageable switch then try to reset the switch.
Mar 14, 2011 | Dynamode (SW240010-R) Networking Switch
press [windows]+[r"\]. type in "cmd" and press [enter]. type "ipconfig /all] and press [enter] find your IP address. type the first two sets of numbers into a web browser and replace the last two sets with 1.1.
you can do a search on google to find the default username and password.
Dec 25, 2009 | Dynamode (HT809STP) Networking Hub
I have now idea how to use it
this is compaq ethernet hub and very easy to use.
just powerup this hub nad give ip to each PC or laptop and connect through CAT5 or CAT6 cable .To ensure connectivity ping PC and laptop .
its working fine.
Apr 24, 2009 | Compaq Netelligent 2016 (267046-001)...
I have a Dynamode 6004 W-G1 wireless router
To improve wireless signal from your wireless router you can try changing the wireless channel of it from the router setup page, set the wireless channel to the highest one so it will avoid interferences on your location........
Jan 15, 2009 | Dynamode (HT809STP) Networking Hub
Dynamode ht809stp
just plug the power connection
and connect the network cables. and restart the computer.
Summary for Dynamode (HT809STP)
Dynamode products have earned a worldwide reputation for quality. The Dynamode hubs products utilize state-of-the-art design and ASIC-base hardware for high reliability.Dynamode offers the 8-port Ethernet Hub which, in compliance with IEEE 802.3 10 BASE-T standard, is a multi port repeater used in the twisted pair Ethernet Network. Featuring 8 RJ-45 twisted pair ports for twisted pair wiring, one AUI port for thick cabling and one BNC port for thin cabling, it allows to connect up to 8 devices (such as twisted pair Ethernet card), an Ethernet Transceiver and a Tee connector.
Sep 16, 2008 | Dynamode (HT809STP) Networking Hub
Need help about Networking
visit the site ,here you can search a tutural for networking.
Mar 28, 2008 | Belkin (F5U237) 7-Port USB Hub
Dynamode BR-6004 W G1
Try holding down the reset switch on the back with the router turned on for about 10 seconds or more.
the following info was found at,com_forum/Itemid,32/page,viewtopic/p,126642/
i believe the default password/username for your router is:
Password:guest wrote:
You should see a box prompting you for your username and password. Enter your username and password now. By default both the username and password are guest. Click the Ok button to log in to your router.
this info was taken from ing/Dynamode/BR6004W-G1/WinMX.htm
Mar 15, 2008 | Dynamode (HT809STP) Networking Hub
Dynamode (HT809STP) Networking Hub Logo
Top Dynamode Networking Hubs & Switches Experts
Brian Sullivan
Brian Sullivan
Are you a Dynamode Networking Hub and Switch Expert? Answer questions, earn points and help others
