Gateway 7322 laptop does not respond to power button -- it will not turn on. Does the laptop have a mother board reset button? Is that button buried somewhere behind panels and dozens of tiny screws?
  • 1 more comment
  • jim941 Jul 31, 2009
    It works now, thanks! I started by connecting the DigiPower supply to another brick, which seems to be a supplemental battery supply/power buffer, but that didn't work. Connecting it directly to the brick farther down the line produced a startup.
  • Michael Beverlin May 11, 2010
    Are you trying this on battery or on ac power supply?? Have you tried a different ac power supply to see if maybe you are just having a power issue??
  • Shraterman May 11, 2010
    Does the laptop recognize that the power cord is plugged in and the battery is charging?
  • 79 Answers
Try replacing the battery or try plugging it into AC power
Posted on Jul 31, 2009
Gateway 7322 Notebook. Can't get the battery only
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 09, 2012 | Computers & Internet
I need to do a System Restore on a Gateway 7322 Laptop
try running this virus FREE prog No cost- removes too...: http://www.f-secure.com/en_EMEA/security/tools/online-scanner/
Jun 29, 2010 | Gateway 7322GZ Notebook
Gateway 450ROG, will not start. Red DVD/CD ROM
I have the very same problem, the Drive light turns red, the screen is "black" and the battery charging light indicator on the front is off. No differance if I'm traying to power up on battery or AC-adapter.
Before this problem appeared I had problems where the laptop was powering off, with no warning, and I had to restart it. This happened several times and was going on for about a week before it died totally. Can it be the CMOS battery on the mother board? Anyone having clue what the problem could be?
Mar 31, 2010 | Gateway 450ROG Notebook
We have proplem in power damage in mother board the led of power on is on put no power in screen and led of HDD is off model no 450 ROG
Remove the battery and power cable from the laptop. Press and Hold teh power button for 20 sec, connect the power chord and then try to turn on the computer
Sep 10, 2009 | Gateway 450ROG Notebook
I have a Gateway 7322 laptop. I'm trying to hook
Press the Fn key down, hold it down, then press the F2 key.
Here is the download page for the Gateway Notebook User Guide,
http://support.gateway.com/s/Mobile/Gateway/7305GZ/4429ul.shtml
Aug 05, 2009 | Dell Inspiron 1525 Laptop
Gateway 510X H Desktop will not power up
Yes, definitely. You need to change your power supply.
Jul 23, 2009 | Gateway 510 X (10272197) PC Desktop
Mother board problem
Go to ebay,if it's not there....you may be out of luck. Did you try gateway? I didn't look it up but they may still service that board.
Jul 15, 2009 | Gateway (4000274) Motherboard
Gateway inverter board replacment
The inverter board is the circuit board inside the screen, with all the capacitators etc that controls the backlight. It looks like this:
http://cgi.ebay.com/GateWay-7322-7330-7340-7410-Inverter-83-120082-3000_W0QQitemZ290289050786QQcmdZViewItemQQimsxZ20090114?IMSfp=TL090114125004r29293
You can just google 'changing inverter board gateway' and see if you can find the closest guide to your model..
I found this one 4th on the list..
http://www.pcgeekdom.com/2006/02/replacing-laptops-lcd-backlight.html
Hope this helps
Chris (ziraffa)
Jan 17, 2009 | Gateway 7322GZ Notebook
Fix the on button on a Gateway laptop (MX7118)
lay down the screen flat
then get the two screws under the power bar
lift up power button bar carfully,you will see ribbon cable connected to the mother board with little brown clips, one on the power button also, this ribbon cable is very thin, and you probably will see the cracks with maginfy, order ribbon cable on ebay
Jan 03, 2009 | Gateway MX7118 Notebook
GATEWAY 7322
If you replace the HDD, there is no reason why system hung up. try cleaning your memory cause on that case i can pinpoint that memory something wrong. try cleaning memory fixed it again, if your don't mind maybe you need to replace the memory.
if the same happen, try examine CD Disc or your cd rom drive cannot read the files on the disc.
(Option solution)Examine your motherboard after clear prove that the above solution is not working. i can assure u that main board is good. if ever it was damage that causes overheating.
Jan 10, 2008 | Gateway 7322GZ Notebook
Computers & Internet Logo
188 people viewed this question
David Payne
David Payne
