Question about Tacsew BLST-2
The needle is not going through the fabric as such it does not hem.
  • Tacsew Master
  • 1,388 Answers
Try a new sharp needle !!
Posted on Aug 02, 2009
How do i sew a hem with a twin needle?
Sewing a hem with a twin needle is done differently than with a single needle. Normally you stitch on the wrong side of the fabric but in twin needle seeing you stitch on the right side of the fabric. Using fusable stay tape to keep the hem in place to sew the hem works well.
This video should be helpful. Watch it in it's entirety and remember some things on your machine may be different.
Sewing the hem will be the same.
https://youtu.be/t5eEPCj-LGE Sewing with Double or Twin Needle
Jul 21, 2017 | Sewing Machines
How to sew a hem with a twin needle please?
How do I adjust tension on a Janome Harmony 9102D
Sounds like you want to do a rolled hem for a handkerchief edge, I do the following to create a rolled hem on my over locker. Take out left needle and cut and remove that thread. Open front cover and slide back lever for the stitch finger in the needle plate, this finger stops the fabric rolling under thread tension normally so you need to pull it back out of engagement. Your Janome may have a similar means to select the rolled hem or you may need to remove the stitch finger with a screwdriver, it varies between models.
Thread upper looper with wooly nylon and right needle and lower looper in matching colour thread. (You can go wooly on the bottom looper but it hardly shows so I never bother.) Disengage upper blade and move the fixed lower blade to the right to trim less, then lower upper blade back into position. Now tension, needle leave alone (5)' upper looper very loose (2-3) and lower looper tighten up to 6-7 and test stitch. You want the upper looper thread to go right underneath and the lower looper thread to disappear against the needle stitch. And the fabric to roll inside the stitching. Finesse tensions on the loopers until this is right, you may need to change blade position too, depends on weight of the fabric and how it rolls. Once this is right turn stitch length down to close up stitching, 0.8 or even 0.5 if you want full coverage. Thats it. You can use differential feed if you want a fluted rolled edge, nice on knits.
Mar 02, 2015 | Janome Harmony 9102D Mechanical Sewing...
Hemming knit fabric with ball point needle but have skipped stitches.
you may need a new ball point needle, the tip to the needle could have some damage to it. How to Choose Sewing Machine Needle for Knits eHow
Feb 21, 2014 | Janome Sewing Machines
I cant get my 1034d to sew blind hem stitch
It is not a special stitch, just a three thread overlocked seam with left needle but you do it with the blind hem foot and fold your fabric into a "z" shape, wrong side upwards and raw edge at the bottom to be trimmed by the blade as you seam. The folded edge is run against the "blade" of your blind hem foot to ensure even "bite" of the upper fold by the needle while the loopers form the seam around your raw edge below. Then when you finish and press the z fold open, you obviously want a little as possible of the needle stitch to show on the right side of the hemline. So you need to practice and adjust the position of the blind hem guide to ensure you are getting the needle to stitch just onto the folded edge.
I have only ever done it on knit fabric, as it does show and not very successful on a curved hem edge, straight edge is fine. You only want to catch a minimal amount of the fabric with the needle, lengthen the stitch length to 3 so there is less stitches per inch as it will show on the right side.
There is a tutorial here on youtube http://www.youtube.com/watch?v=aDJbFNZrCUI
Nov 13, 2011 | Brother 1034D Mechanical Sewing Machine
I need to know how to do the blind stitch hem
here is a link to great info on sewing.about.com which explains this technique with images, http://sewing.about.com/od/techniques/ss/machineblindsti.htm
In brief, you need to fold the fabric to be hemmed into a Z shape with the wrong side hem edge at the bottom of the Z.
The Blind stitch is either three straight stitches then a wide zig zag which swings to the left and catches a little bit of the folded edge, or three small zig zags, then one wide zig zag to the left to catch one stitch into the folded edge. The zig zag style has a little more stretch in it so works good on jerseys and knits.
tally_girl_0.gif You need to use the blind hemming foot which helps you to line up the folded edge and keep it at a constant distance from the needle. It will look like this.
tally_girl_53.jpg Turn the little silver screw to move the white plastic guide left or right until you've got just a smidgen of fabric being stitched by the left wide stitch. Always do a practice sample first to get the stitching and guide set right. On most machines you can vary the width of the big zig by adjusting the stitch width dial a little.
You need to adjust the blind hemming foot guide so that the needle is just catching a tiny amount of your folded fabric because this is the stitch which shows on the right side of the fabric when you unfold the Z. So forget trying to hem satin or expensive fabrics this way, a hand sewn stitch will give a much better finish.
Blind hemming works best on a hem which is continuously straight on the same grain line, its not great for a curved hem. So if you've got a tiered skirt or the frill on a bed valance, it is fine as the fabric edge to be hemmed will be a continuous straight length. You can use it on a slightly curved hem for jerseys as the fabric has more give, and patterns will help to disguise the stitching too.
I hope that this helps you to sew your blind hem, 4 thumbs up if so.
Jul 19, 2011 | Brother LS2020 Sewing Machine
I've got an Elna 634 overlocker, and want to turn
Just trim the fabric to the desired hem length plus one inch, then overlock around this raw edge with thread close colour match to the fabric.
You then have the choice of either stitching around with a stretch stitch on your sewing machine, or hand sewing.
Being lycra shouldn't change how you hem them unless the trouser leg is extremely close fitting and the hem seam is going to be under tension.
My first choice would be using a twin needle in straight stitch from top side but this finish can pop/break if the hem is under tension. But perfect for most knit hems.
If you hand sew then you can turn up hem allowance and put a length of fusible hemming web inside the hem allowance and press it to hold. Then do a back stitch hand sew around to hold hem in place.
If you sew with the regular sewing machine, then use either the stretch stitch or a very small zig zag, and a ball point or stretch needle.
On ready to wear you would see a coverstitch hem but your overlocker doens't have this stitch.
Jun 12, 2011 | Elna Sewing Machines
Hemming stretch fabrics
You can use a twin needle if you want the look of top stitching (like t-shirt).
For the blind hem, you need to baste the hem and then the fold so they do not shift as the machine stitches the hem.
I like to test each of these techniques by making a sample with the same fabric and adjusting length when using the twin needle or width and length when doing the blind hem.
Twin needle does limit the stitching to a straight stitch or a very, very narrow zig-zag - this has to be hand walked to be sure neither swing hits the presser foot or needle plate before stitching.
Feb 22, 2010 | Sewing Machines
Sewing machine needle breaks when I get to the edges where the fabric is thick and overlaps. The needles don't break anywhere else. Do I just need a bigger needle?
I will stop at the overlap and slowly go through the fabric by turning the wheel manually and carefully handling the fabric with both hands, for example, when hemming bottoms of pants where the seams are
Dec 13, 2009 | Singer Sewing Machines
Rolled hem on chiffon
Turn under the edge just about 1/4" and do a rolled edge then you can go back and trim off any of the folded under fabric that may show. Also, this keeps the hem from pulling away so easily. You may also try putting some water soluble stabilizer under the fabric before you serge.
Jul 03, 2008 | Baby Lock Eclipse Serger
Sewing Machines Logo
52 people viewed this question
Top Tacsew Sewing Machines Experts
Shehu Pro
Shehu Pro
Nick Olsen
ray gallant
Are you a Tacsew Sewing Machine Expert? Answer questions, earn points and help others
