My ac will not stay on when its at a certain temperture or auto. only if its in on position
  • 25 Answers
This is correct because if you set it to certin temp. when it reaches that temp. it will shut down to prevent over cooling when the temp in the room goes up a preset amount 2-5 deg.(preset by manafatuer) the unit should go back on to drop the temp. to your set temp. Auto works the same way, where just on will cool to the temp the system can cool efficently.
Posted on Jul 31, 2009
2012 traverse, air conditioner kicking off temperture is hot ,went to auto zone and they put on computer . no codes showed up any help
May be pressure related. They have a pressure sensor that stops the compressor if the pressure gets high. People sometimes make the mistake of adding too much when messing with the AC. Get a qualified mechanic that can work on AC and check the pressure to inspect it.
Apr 15, 2017 | Cars & Trucks
How does ac evaporative coil with piston work?
the evaporater coil's piston acts as a orfice. the size of the piston hole allows a certain amount of refrigerant through at design pressure. it produces a designed temperture drop at designed cfm of air across it.
Jun 19, 2014 | Goodman Heating & Cooling
2003 Lincoln Navigator, I cleaned my center console panel (AC/Heater control knobs) because of sticking buttons now the buttons (Auto, Off, Dual, etc) does turn on or off AC/Heat, nor does the display...
shudnt hav done that-u caused corrosion--now u need to take um out and see if their salvagable--getta haynes manual or sec629-ur local library
Nov 20, 2013 | Lincoln Cars & Trucks
Engine not hot temperture red lines ac and heat stop until the hand come back down
Could be a faulty temp sensor. You should have the computer scanned for trouble codes and check the sensor operation.
Also make sure the radiator is full of coolant.
Sep 16, 2012 | 2001 Subaru Forester
My Norcold N611 frig code flashes 3 time every few second and doesn't go into A/C mode and will only go into gas mode when the switch is in auto mode and the interior light stays on even when the
The N611 will flash 3 times as an AC heater fault. If your AC heaters are ohming out properly (48 ohms of resistance), then you have a bad power board. If the AC heaters are not showing around 48 ohms of resistance, replace the AC heater. It's going to be one of the two. Here is an article on it:
Norcold Fault Codes AC HE or On light flashing 3 times What to do
Aug 16, 2012 | Refrigerators
Cooling fans only come on when ac is on what could be the problem
there is a fan control switch in the cooling system. since both fans run with a/c on, this is most likely your problem. you can check the fan relay and see if the switch is supplying ground to activate relay.
Jun 30, 2012 | 2000 Buick LeSabre
I have a goodman cpk j42 -1b ac unit on the outside and a central heat and air unit inside. the ac unit come on and runs fine but when it hit the temp the thermastat clicks and the fan outside goes of but...
Hello BWOOD Check the thermostat FAN button is in AUTO position not ON position.That might be it .The relay is in the blower unit but they RARELY become frozen/welded stuck on.
Aug 30, 2010 | Heating & Cooling
With AC on cold, Drivers air full hot & passenger side full Cold
that is a good possibilty, but before I pulled the trigger I would try this first. unhook the battery for 5 minutes, rehook it, now turn the key on, wait for 2 minutes, now start the truck and see if the doors now work. sometimes this works, its worth a try.
Sep 26, 2009 | 2005 GMC Sierra
Blower stays on with new themostat
Check to see if there is a short between the green wire and the red wire. Green is the fan control wire for AC. Sounds like some wires may be touching. How did the old t-stat get fried?
Jan 02, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
46 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
