A laptop and all those we take out the old useless shorted battery now, and run on AC pack only , even for ever.
that is test 1.
the next most common failure is, the vents and whole PC is packed in lint and overheats, endless failures here.......endless.
all PCs slow down when too hot, by DESIGN.
first BIOS does that then Intel inside does it next.
SOURCE: Dell Inspirion 1000 power short circuit
Good Evening:
Hope that you are wellJ
If I can be of further assistance, please let me know
And, remember; always include the type of Operating System and the type of computer you own, when you submit your questions. It simply makes for much faster solutions.
Have a wonderful weekend.
SOURCE: how to turn on wirelss on a dell inspirion
Ok now firstly you have to see whch inspiron laptop you are acctually using. The procedure is same in most of the cases and here it goes... If you are uing somewhat older inspiron 1525 then there is a wireless switch on left side.just slide it to activate it. On newer inspiron 1540 wireless switch is on keyboard itself...Check out the F2 key.Its the one for wireless now...In some cases you might have to push Fn along with F2.
SOURCE: Acer Netbook won't turn on
check the system ram and try another one
try too boot the the system without the ram ie check whether it gives a beep or not if the ram is ok then there could be a problem with the system bios
SOURCE: my dell inspiron 1545 won't
Hold down the power button for 10 seconds. That will hard-shut the PC. Once that is done, fire it back up, and try again. Somethimes, windows will act goofy shutting down. Especially Vista when it is left on too long without shutting it down.
