Question about Panasonic PT-51HX41 51" Rear Projection Television
Projection tv lamps
Do these lamps fade with age? What is the useful lamp hours.
Will screen dim as lamp ages?
All fillament based lights will dim as they age. Some of the newer/better types it will be unnoticible.  If you are losing image quality or brightness you may have a bulb that is nearing the end of it's life cycle.  A glance at you owners manual or the manufactor's website should give you an indication of the expected life of your bulb.  Also most of the projector made in the past few years have a counter that tallies the amount of hours your bulb has been on.  A more likely culprit is probably dust accumilation somewhere inside your projector. Most projectors have filters these days and need to cleaned at certain intervals and in certains ways.  Not cleaning these filters can cause heat build up that can increase operating temps and shorten the life of your bulb and or projector.  Or sometimes jsut fail and cause a dramatic decrease in image quality.  Again these things are vendor/model specific so you will want to check with them about your particular model. Hope this helps.
Posted on Nov 24, 2007
  • JOHN ALVAREZ Sep 18, 2012
    HELLO ! I have a Panasonic PT51HX41E the TV was working perfectly until i moved it from one room to another. I can hear the sound but i cant see the picture. Wierd.. I tried the reset factory but it didn't work. I have tried changing the tv input but it doesnt work all i can hear it the white noise until i reach the input and i can then hear the sound of the TV but i cant see the picture. I oppened from the back i i saw 3 lamps on the bottom. They are all glowing but that about it. Has anyone had the same problem? PS I tried to put the tv on a table so i was taller but i couldn't lift it allt he way because it was to heavy. ALL i did was lift one side about 30 degrees and put it gently back on the floor. Did i screwed something by trying to lift it from one side?
Brightness problems with sony kf-50we610
This is typical for a set that uses a lamp, as the lamp needs to warm up.
If it is taking longer than normal to brighten up, then your lamp could just be aging and needs replaced.
Jun 19, 2012 | Sony Grand WEGA KF60WE610 60" Rear...
Turn set on picture is dark.. if I leave the TV on.. in several hours it's viewable.
I have seen several Samsung's including 3 that were only a few months old at the time where it was the lamp---one was so dim it was very hard to even see the picture or that the screen was lit.
Two suggestions here: One of course would be to buy and gamble and replace the lamp.
What I found in two of the three cases was when I removed the lamp the glass pillar inside it was "bent" at a angle from heat or a natural defect--in both those cases a new lamp cured this dim picture issue.
Set will monitor the lamp and if too dim may shut set off or even blink for a prolonged period of time.
If the lamp is over 2 years or age (average life) or was replaced with a non-Samsung lamp you are going to have to take the gamble to try another one.
Inspect the lamp---that pillar supports the filament and if bent the lamp is suspect at best.
May 20, 2012 | Televison & Video
I turned on my projecter and the screen was not bright enought
There is reduction in brightness due to aging of the lamp. Normal life of projection lamp is 2000 to 5000 hours depending on the mode of operation. In power saving mode it is more. Please see the manual for specifications. If you have switched from standard mode to power saving (economy) mode, the brightness will reduce. If it is not then check the number of lamp hours & replace the lamp accordingly.
Jul 18, 2011 | Televison & Video
The display projected is very faint. The lamp light is not blinking to indicate a problem. Is this an issue with the settings?
Check the bulb hours remaining through the menu. The bulb gets dimmer with age, so it could be close to life expectancy (2000 hrs regular, 3000 hrs Eco) and failing. The indicator light is based on hours only and will shut down the projector after (2100 or 3100 hours of bulb use), so it could still be the lamp failing or a power supply issue, especially if it's dim right from start up. Hope this helps.
Feb 08, 2011 | NEC VT695 LCD Projector
Screen is dim. Have brightness turned up to max setting. Does the lamp get dim with age? Mitsubishi WD-Y577 dlp rear projection tv
Yes... from the moment the lamp is put into service, it begins to deminish in brightness. You should order a replacement lamp to have on hand.
Mar 15, 2010 | Mitsubishi WD-Y577 Television
My TV is getting dimmer and dimmer.. why is it not bright?
yes i agree the TV lamp it's done.
a lamp last like arrownd 4000 ans 7000 hours depends on the lamp brand..
i will give you a link that u can used and a video so you can change it it's so easy
good luck!
Jan 15, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
The lamp will dim as it ages and will do so quicker as it approaches end of life.  Do you know how many hours the lamp has been used.  How old is the TV?
May 27, 2009 | Zenith E44W46LCD 44" Rear Projection...
Screen getting dark
If you have never changed the lamp this is more than likely the issue, as the tv ages the lamp looses brightness. Most lamps are rated for 3000-5000 hrs of use. Replace the lamp assembly part # UX21514 and you will notice a much brighter picture. You do not mention if the tv plays the right colors on the entire screen. These have had light engine issues.
Good luck with it
Apr 07, 2009 | Hitachi 50VX915 Rear Projection Television
Problems with brightness on the hitachi 50v810
Yes, they dim as they age, and you've done well to get 3 years out of one.
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. really easy.
Jan 02, 2008 | Hitachi 50VS810 50" Rear Projection HDTV
Dimming picture
Sound like the lamps are ageing or the lamp PSU is playing up.
Apr 10, 2007 | Mitsubishi VS-50705 50" Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
277 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
