SOURCE: Bottom hinge on fridge door broken
Yes, there is supposed to be a plastic bushing/washer under there. Usually 1/8 inch thick. If a dealer is not handy you may cut some out of plastic to put there. Then undo the top hinge, and carefully lift the door off (you might want to empty the shelfs). Put your spacer on the hinge pin, and replace the door and the top hinge.
SOURCE: self closing door hinges
This is not a refrigerator problem BUT, you must insert a tool like a drift punch into one of the holes on the top of the hinge and rotate it away from the door position then reposition the holding pin to prevent it from recoiling.
SOURCE: DCS 30 inch oven door fell off
First thing is be careful them sprins are strong and will hurt your fingers bad if not careful. That said place both hinges in 1/3 open position they should stop there. if not put both all the way open then slide door back on and close. supposed to only lift off in 1/3 open position but whatever works.
SOURCE: Sienna sliding door hinge replacement
I have exactly this problem on my 2004 toyota sienna. Just started happening and the door now rubs the edge of the rear quarter panel as the door opens and closes. Any help on how to replace the middle hinge would be appreciated.
Removal of Cabinet
(Do not use decorative panel to move the machine)
1. Isolate power supply.
2. Remove service and decorative panels (refer Section 6.1).
3. Ease machine forward for all round access. Be careful not to damage floor coverings.
4. Remove two screws from bottom sides of cabinet rear.
5. Remove the top screws on left and right hand sides of the cabinet rear.
6. Remove two screws securing the rear bottom panel.
7. Remove five screws securing the stainless steel frame to cabinet wrapper at front of machine. These are located behind the sound gasket and service panel.
8. Withdraw the cabinet assembly away from the machine.
Refitting: Refit in reverse manner. Fitting the top centre screw in the cabinet wrapper first, makes fitting the cabinet easier.
6.9 Removal of Door Tension Springs
Location: The door tension springs are located either side of the machine and are
fitted to the chassis base and door quadrants by means of the end hooks of
these springs.
After isolating the machine from the power supply:
1. Ease machine forward for all round access.
2. Remove service panel (Refer Section 6.1).
3. Remove two screws in the cabinet wrapper exposed by the Service Panel.
4. Remove the springs from the quadrants and the chassis base using pliers.
6.10 Removal of Hinge Assemblies
(Do not use decorative panel to move machine)
Location: The hinge assemblies are located either side of the door and retained by means of two rivets on each side to the inner door panel.
1. Remove service & decorative panels (refer Section 6.1).
2. Remove outer door panel (refer Section 6.2).
3. Remove cabinet (refer Section 6.7).
4. Remove door tension springs (refer Section 6.8).
5. Remove quadrant grommets.
6. Open door fully and drill out the two rivets from the hinge assembly on inner door panel.
7. Hinge assembly can now be removed from inner door and cabinet.
Note: Hinges should be replaced one at a time. Repeat procedure six and seven for other hinge. Hinge guide quadrants can now be removed by depressing sides and pulling free of slot if need be.
Refitting: Refit in reverse manner using 3/16 monal rivets to secure the hinges to the inner door.
