Question about Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M
Chatters / something is hitting and slowing down the blower but when I took it apart I couldn't see where anything was rubbing.
  • 77 Answers
Sounds like may be piston rod broke or fracture,take plug out,get flashlight,pull the cord slowly and get a good look,I bet its in there.
Posted on Aug 10, 2009
Fan making clanking noise like it is hitting something the part seems to be located in the lower left front passenger side
sounds like blower motor fan for heat, the motor itself can be going bad or something is hitting fan blade inside heater box, I have seen all different things in heater boxes including acorns , leaves and general debris causing noises when fan for heater runs, you need to take it apart and check for anything that might be hitting fan if not motor is going bad and needs replacement, good luck.
Apr 04, 2015 | 2005 Dodge Caravan
Sounds like fan inside blower housing is hitting something when motor is running.
It sounds like you may have a cracked or broken impeller
Nov 10, 2014 | Vacuums
2005 Dodge Ram 1500 4x2 - Drivers side front wheel feels like it is catching on something.
Have you not looked over the brakes & even taken
things apart, looking for & eliminating brakes as an issue?
Checked drive axles,joints,etc.
Tires won't make a noise & brakes are not near the wheel,
to touch anything
New wheel hubs are ruined by mechanics obsessed with those
air driven impact guns,you need to use a torque wrench on the
axle nut of a new bearing
Jul 16, 2013 | Cars & Trucks
When spinning at higher speeds, there was a sound that could only be the drum hitting or catching something. The drum has now dropped about an inch. I took it all apart yesterday & could see nothing...
It's hard to give much detail without a model number, but it sounds like you are working on a front load washer.
If the tub of a front load washer has dropped down and is rubbing on the outer tube as it spins around then I would suspect the rear drum bearings are bad.
You can remove the back access panel from your washer and see if there is a trail of grease and water residue running down from the center tub bearing.
Aug 03, 2011 | Washing Machines
So I picked up a 2006 mini last year and I noticed in the last couple of months that the overflow tank goes empty every couple of days. I hadn't noticed anything on the ground until I had my oil...
Start on a day you're not using the car. park it in a spot where any fluid leaks will be imeadiately obvious and if you see a fluid leak jack the vehicle on the spot and get under it and start looking for wet spots. It could be something as simple as a bad or loose hose clamp.
Jun 24, 2011 | 2006 Mini Cooper
Whirlpool ywed5800 dryer has loud noise coming from flint trap, almost a motor noise
Hello- If you take out the lint filter can you see anything down inside? It seems like there may be something hitting the blower wheel or the internal ducting may have come loose... You may have to have someone out the take it apart and try to locate the problem. Best regards.
Sep 26, 2010 | Whirlpool LER4634J Electric Dryer
I have a kenmore microwave hood combination model 721.80019. The blower unit has recently started squealing when we run the microwave. I am not sure if it is rubbing up against something or not. Is there...
I just found out the same problem with mine.
I think the bearing of the fan motor has problems.
I took it apart and now looking for a used or new fan motor unit.
Bill
Aug 14, 2010 | Kenmore Microwave Ovens
After a couple of hours of use last week, the motor started slowing down. Turned it off and it would not restart. tried again after an hour and it started but sounded really rough. stopped it and took it...
sounds like the motor is worn out. Toro does not sell the motor separate. It is considered a throw away unit.
You will have to purchase a new one.
Sorry.
Good Day.
Nov 05, 2009 | Toro Electric Ultra Blower/Vac 12 Amp
Same symptoms
There is a safety switch to make sure you can not power the unit while it is apart. Sometimes this switch will break when you open the unit. Bottom line most manufactures if electric tools and appliances do not want tou screwing with their stuff.
Sep 12, 2009 | Toro Blowers Rake and Vac - Electric...
Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M Logo
67 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
