SOURCE: Always paper jam.
Check to see if something isn't blocking the paper path.
You could try cleaning the feed rollers as well.
SOURCE: ricoh aficio 150 paper jam
There are pressure release levers on the fuser --- if they are not in the correct position they will not apply the proper pressure and you will get jamming in that area. The levers are either a light green, light blue or plain black. They should be on the left and right side ( looking in at the fuser. Turn/ flip them and check.
SOURCE: paper won't feed into printer. Always gets jammed
you must have objects foriegn objects inside your printer. i.e. paper clip or some other object . Get your printer and move it side to side see if you can here anything moving about. once its out then perform alignment of rollers using epson maintenance menu.
SOURCE: Carriage Jam on my HP Officejet 5610v All-in-One printer
If I move the carriages to the center of the bar they slide on (would be the center of the paper) and close everything it seems to re-load, I've had to do this several times over the last few years and so far it always works
SOURCE: removed paper after paper jam and have opened all
