Question about Dehumidifiers
The fan seem to have quit working and the unit got loud. i oiled the fan but it doenst turn on but the compressor comes on but overheats quickly.
  • David Shaub May 11, 2010
    Make sure the fan is tight on it's shaft. It could be spinning freely, not cooling the compressor.
    Guru:
  • 587 Answers
Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
Posted on Aug 25, 2009
It is very loud and gives an instruction in the form of E1 then it switches off eventually.
Wild guess, the fan is not working as it should. Too slow or perhaps bad instruction from the "brain". I would guess after some time of "cool down" It will turn on again and do the same thing? Not likely, but the filter needs to be changed, or the coil is
very dirty and cannot "dispose" of the heat fast enough so the compressor works harder, gets too hot and It's overheat switch stops the compressor.
Mar 27, 2015 | Dehumidifiers
I have a Haier dehumidifier Mod 39R131F that is two years with 100 total hours that does not work. The compressor is humming normal but the in and out R22 copper lines remain at room temp. Under the...
Many of these consumer units use low grade copper for their refrigeration connections. The oil is a sure fire indicator of your seemingly correct diagnosis. Unless you have the proper refrigeration tools to repair and recharge the unit it may not be cost effective to try for a repair, as if this is the issue another leak is likely to occur. Many of these units come with 5 year compressor warranties though, so a quick check to make sure the leak is in the refrigerant piping and not on the compressor itself may be worthwhile. If your warranty has not run out it could be beneficial to find the exact source of the leak.
Sep 25, 2011 | Dehumidifiers
Fan is running, compressor seems to be working fine, i noticed some oil spill through water outflow opening. Need your quick response.
Are you sure it's oil and not just some gunk that was left in the drain tubing? If would be kinda hard for oil to get in the drain tubing. For now, just keep an eye on it.
Jul 03, 2011 | General Electric AHR50LM Dehumidifier
Humidifier compressor does not stay on more than 1-2 minutes
Sounds like bad relay on compressor or bad compressor. There is only so far you can go yourself without knowledge in electrical and AC units. Suggest you call a service tech or if you can take it to service cemter near you. Russ
Jul 24, 2009 | Kenmore 5230 Dehumidifier
Not collecting water,
IF THE COMPRESSOR QUITS IT WILL NOT PRODUCE MOISTURE COULD BE LOW ON GAS,BAD HUMIDISTAT,DIRTY CONDENSOR CAUSING UNIT TO OVERHEAT SHOULD SEEK TECHNICIAN
Jul 20, 2009 | LG DH30 GoldStar Dehumidifier
Oil inside the water collection res
the compressor runs in oil. suspect you have a quite bad leak and loss all the gas - hence no water collection and the compressor oil is being pumped out thro the leak
Jun 26, 2008 | Whirlpool AD25BBK Dehumidifier
Makes a loud noise
not sure which dehum yo have,but here I go! most fans are not part of the cooling system. first remove the housing where the fan is. turn the unit on and check to see if the fan is turning. if not then just wait till you hear the compressor kick in. if the compressor goes on then you do have a problem w/the fan motor and it will have to be replaced. worst comes to worst just bring it into Sears. they have techs which will let you know what the exact problem is and you can take it from there. make sure you give them the model # first,just to check if the have parts for your dehum.
Dec 18, 2007 | Eva-Dry EVD1100 Reable Petite Dehumidifier...
Doesn't want to stay on...
Most likely the fan motor has broken. Without the fan, the compressor will overheat. There is a safety device inside that automatically shuts off the compressor to keep the overheating from destroying it. Check to see if you can feel air movement in the front or back of the unit while it is running. If not, then the fan motor has definitely broke. I had this exact problem on mine.
If you take the unit apart, you will find a parts list inside the unit. It will be inside a small plastic pouch. You can order a new fan motor from Sears. The cost is $30 plus shipping.
You will have to move the condensing coil in the front out a bit in order to exchange the motors. Just be careful not to break any of the copper lines. They are copper so they will flex quite a bit without breaking. Still, use caution. If you break the lines, all the refrigerant will leak out and your unit will be useless.
Sep 01, 2007 | Kenmore 54501 Dehumidifier
Dehumidifiers Logo
147 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
