Question about Samsung DLP HL-P5663W 56" TV
42 inch Samsung DLP TV shuts off by itself. I can turn it back on and sometimes it stays on and other times shuts off within seconds. Some days it stays on all day without a problem. Other days it shuts down several times. I am getting very tired of this set. Any easy fix. I have in the 3 years I have had this set replaced the bulb and the color wheel which came apart. I like the picture but am not happy with the constant problems.
I bypassed the safety switch (it was bad) and vacuumed and blew out all of the dust. So far with this set, 3 years old, I have replaced the bulb twice,it exploded both times, and the color wheel which also exploded! We love the picture but the next time it goes out, it goes out to the trash and I will purchase a top of the line LED/LCD set. No moving parts!!! Samsung designed and manufactured a whole bunch of lemon sets and will not admit it. I have found several hundred complaints about their DLP sets and only a few on other brands.
Posted on Aug 01, 2009
I have a Samsung HL-R5678W DLP TV that is acting up. When I first turn it on everything works, after 5 minutes it shuts itself off. After 2 minutes it will come back on without sound. It will do this a...
U turn tv on hear any squiling,grinding or motor noises?Picture show up before it shut down picture have flashes of black&white within the picture?Yes,to all of these,this tv have a colors wheel and it dead,require the colors wheel replacing.No,none of these problems.The tv projection lamp,if in this tv like a 1 1/2 or 2 years,tv ben on an watches like 4 or 5 hours a day?The "LAMP" LED light indication lite up or flahes,the projection lamp life is over.Require a new projection lamp.
Oct 22, 2010 | Samsung DLP HL-P5663W 56" TV
Our RCA high-def 52 inch TV is shutting off on
It has you Posted as a projection TV and Not DLP, if Fan to Lamp stops running set will shut off to protect Lamp,I had a DLP that would play sometimes 30 mins then shut off drove me crazy trying to firgure it out and it turn out to be Fan would stop running I replaced Fan TV working fine . When you remove back engage toggler switch to up position put a piece of tape on it to hold it is a safty switch ,then turn tv on watch to see if all fans are running also if when tv trys to come on is there a spark coming from Ballast Board if so your new Lamp is defective it does happen if not your ballast board maybe Bad it is what turns on Lamp.If all fans are running Ballast Board.
Sep 22, 2009 | RCA HD52W56 52" Rear Projection HDTV
Samsung HL-r4264w 42 inch dlp projection - Component inputs
I have seen that sometimes the solder becomes loose on the input board. If you are under a warranty I would call and get someone to check it out.
Apr 19, 2009 | Samsung HL-R4264W 42" DLP HDTV
Samsung DLP 62 inch turns off by itself after being switched on
take off the lamp access door on the back and find the safety switch that the door pushes on. unplug the connector from the switch and put staple into the connector to short out the cable. Switch is probably bad. worked for me. same problem.
Apr 07, 2009 | Samsung 61" Slim-Depth DLP HDTV
I hope you can help me.. I own a Samsung DLP TV model no. HL56A650C1F, 56". The problem I am having is that it just turns off by itself and attempts to restart itself continuously. I hear all of the...
I hope you can help me.. I own a Samsung DLP TV model no. HL56A650C1F, 56". The problem I am having is that it just turns off by itself and lights "stand by" and "lamp" are flashing at same time.Sometimes, when I'm trying to turn it on- it shuts off by it self.
Mar 05, 2009 | Televison & Video
Samsung dlp HL56A65 turns off and on by itself
It looks power board problem.
You need to get service from Samsung.
Mar 04, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP 56' TV turns itself off when I initially turn it own. (I turn it on, then it shuts off for approximately 5-10 seconds and turns back on. Sometimes it does it a couple of times before it stays...
The problem is with the ATT UVERSE HDTV BOX and not the Samsung DLP TV. There is an inherent problem with the ATT UVERSE HDTV Box when using a HDMI cable. This was verified by the ATT UVERSE Technician.
Thanks,
Dec 13, 2008 | Televison & Video
Samsung dlp hdtv turns itself off
Have a 46 inch behaving the same way. I have the extended service contract, so they are getting a calll tomorrow. I ll post what they say
Dec 27, 2007 | Samsung DLP HL-P5663W 56" TV
Problem with tv turning off by itself.
I had a friend with the same problem. He had to clean the components and fans in the set. The accumulated dust had caused the set to run hot and a safety switch was the tv off. He purchased a few cans of compressed air and, as he blew the components and fans out, used a vacuum to capture the blown dust. Good luck.
Dec 27, 2007 | Samsung HL-S4266W 42" HDTV
Samsung DLP HL-P5663W 56" TV Logo
569 people viewed this question
Henry  Thomas
Henry Thomas
