Question about RCA DRC8335
My drc8335 just says hello, thats all it will do...unplugged -reset still the same
    Problem Solver:
  • 8 Answers
The DVD drive is bad. When the unit boots up, it searches for the dvd drive. If there is a conflict it freezes on Hello
Posted on Aug 02, 2009
RCA DRC8335 No power
Could be a faulty power supply in the actual unit. Check inside it for a fuse on the circuit board while its unplugged could be blown. Usually power into unit is higher AC voltage (DEATH) and a transformer lowers the voltage so if you take it to a technician they should be able to measure the lower dc voltages to see if the power supply is working ok and if any fuses are blown.
Jan 12, 2014 | RCA DRC8335
Plug drc8335 in I get hello but will not turn on
That is the same problem I had with mine. The problem is one (or two) of the capacitors on the power supply board. If you can solder you can replace them yourself for a few bucks. You can tell which ones they are by looking at the tops of them and they will be bulged out slightly. The fixes I found mentioned one specific capacitor, but I found a 2nd one that was bad as well. I replaced those and it worked fine, although it will freeze from time to time after constant use, I haven't gotten to diagnosing that problem. I just have been unplugging and plugging it back in.
Jan 25, 2011 | RCA DRC8335
My curtis DRC8335 IS STUCK ON HELLO - WHAT SHOULD i DO - I TRIED SWITCHING IT OFF - SWITCHED IT ON - STILL STUCK ON HELLO
There's a blown capacitor in your machine (when you open it up, the capacitors are the little things that look like pop cans). If you are good with a soldering iron (or know somebody who is), they should be able to replace the blown capacitor with a minimum of fuss. I believe the board location is C226.
Feb 11, 2010 | RCA DRC8335
Unit just gets stuck at Hello sign. Reset unit several times. Unplugged and replugged unit, but didn't fix problem. No menu items display on TV. Unable to open DVD tray. Unable to play or record VHS tape....
You have a blown capacitor in your machine. If you are good with a soldering iron, great, you can fix it yourself. Otherwise, find a friend who is good with a soldering iron. Parts should cost you less than $2 for a new capacitor. Replaced the blown capacitor in my machine, and my tape popped out with no fuss once I powered the system back up.
Jan 13, 2010 | RCA DRC8335
Recorder will not do anything only hello hello. I have unplugged for 10 seconds or more and still nothing happens
recorder will not do anything only hello hello. I have unplugged for 10 seconds or more and still nothing happens
Nov 16, 2009 | RCA DRC8335
I have drc8335 dvd burner all it does is say hello
The dvd drive is bad. It is hagning on load up, hence the hello screen
Jun 22, 2009 | RCA DRC8335
When turned on stays stuck in Hello mode and nothing works.
You cant solve this problem . This is internal problem . So you first contact the experienced mechanic. do first
Jun 02, 2009 | RCA DRC8335
Unit unresponsive - see detail below
Thanks to the help on this forum, I was able to fix my DRC8335 power supply. C226 was the problem, went to Radio Shack and found the 470uf 35V replacement. It came up and worked like a charm after soldering it in. (See the picture of the cap on the board). It was just slightly swollen when viewed from the top but when i removed it, the bottom was really distorted. Thanks to micro065 and Mike Powellebbca66.jpg
Dec 31, 2008 | RCA DRC8335
RCA DRC8335 Logo
466 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
