No picture - when set is switched on, there is no picture, this can go on for a few minutes or a few hours
  • 188 Answers
Could be the power supply for the inverter but also the LVDS panel.
Posted on Jul 31, 2009
New power supply board and screen goes black
It sounds that the off timer has been set to one hour. Check it.
May 29, 2013 | Philips 47PFL3704D 47 in. LCD TV
Green tint on screen especially with dvds. picture also cuts out for a few minutes every hour or so on our sony kds-50a2020
Usually in this set if screen gradually changes to something other than black and white the optical light engine is the problem---major part.
Google the model number with "problems" or "light engine" to learn more.
Aug 28, 2012 | Sony KDS-50A2020 Television
Sometimes the picture rolls for 30 minutes to one hour and then the picture is perfect. A few times when we turn it on, the picture is okay and then after a few hours, the rolling picture starts. Where is...
The rolling is a bad filter capacitor on the signal board in the set---Any Mitsubishi dealer can look the model up and see known faults including this one---some of the sets when cold---vertical jitter in picture or just menu---If the menu is stable you have a tiny bad cap= weak caps when cold act up and when get hot regain capacitance and start to work.
Aug 28, 2012 | Mitsubishi WS-55807 TV
MY PICTURE KEEPS FREEZING AFTER A FEW MINUTES BUT SOUND REMAINS
Look for any jammed buttons on the remote. Try changing the input device to something you are sure, works such as a DVD player. Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 04, 2012 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
How do I set the clock on a room tech beingz
There is a switch on the back to set time, alarm, or display time. Select the switch to time set first. Tap top of unit to toggle between settings blinking display is the one to be set. Change it bi tapping on the sides ( ) or(-) don't forget the 12 hour display or military 24hour. Switch back to clock display when hour and minute display are both blinking or the setting will not take effect
Jan 26, 2010 | Hasbro Room Tech Beingz Alarm Clock Radio...
SOny TV starting problem
this is a pictur tube prublum. but this prublum is fixed
set filament voltage is 4.5v to > 6.0v
check G-2 voltage on crt base and cancting PF replace.
check 200v dc on crt base and replace 10uf/250v capaciter
Oct 30, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
No Picture
check the blue disc capacitors around horizontal output for a burn mark.
Dec 28, 2007 | Philips 26PW6341 26" TV
HV Sound no Picture
Sounds as though there is an intermitant, heat-related problem with the HV transformer. You can order this at a tv parts shop or from Sony (probably more expensive) the part number should be on the part or on a schematic. If not, the parts dealer can look it up from the model number.
Good luck! :)
Dec 27, 2007 | Sony KV-36XBR400 36" TV
Black out ?
There could be bad solder connections on C809 and C810. There was a technical bulliten on this problem a while back agao. good luck
Apr 29, 2007 | Toshiba 57HDX82 57" Rear Projection HDTV
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
