Question about Irons
Iron needed descaling so followed instructions on descaler lots of debris refilled tank with clean water to flush through but after priming the iron for a very long time, no steam come. Red light was still flashing but after quite a while stopped, still no steam. Thought perhaps I needed to install new filter cause the old one, which was still in iron, may have been too blocked to allow steam through, but that didnt solve the problem. Please can you advise as to what the problem might be. Thank you.
  • 67 Answers
It may be cheaper to buy a new one from wallmart or similar store.
Posted on Aug 04, 2009
No steam coming throwc
Normally when water is put inside steam irons, it get stored in tank then if thermostat knob is set for steam then water moves to bottom heated portion of iron. Water converts to steam as base plate is hot, heated steam comes out through perforated holes. If holes are blocked due to scale formation steam flow is blocked. The descaling has to be done as per instructions given on descaling wax manufacturer. sometimes if water does not enter through a rubber washer that is water tank to heated bottom portion then also steam will not get generated hence no steam. Please check above points and identify the problem.
Jan 08, 2015 | Irons
How do i descale a team international steam pro 2600w iron
Buy a bottle of descaler and put it in the tank where you normally put the water. Put iron on hottest steam poison and run steam , topping up as required. Rinse thoroughly when finished and iron has cooled. Use distilled or demineralised water for steaming and the iron shouldn't require cleaning again.
Dec 02, 2014 | Irons
My steam cleaner was working, then when i refilled it, it didnt heat up. its a multipurpose with different attachments. could it be element gone?
follow this steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Sep 30, 2013 | Conair Compact Garment Steamer Iron
My Philips steam iron Easy Care 3232 oozes brown liquid through holes when used on steam. How can I clean it?
Periodic Descaling of the iron will help reduce this.
Mineral deposits in the water will remain inside the iron after being converted to steam. This builds up over time as scales unless cleaned.
For descaling instruction, refer to manufacturer.
Aug 26, 2010 | Irons
Our iron keeps shutting off and on. It then spurts out brown liquid from the iron. It is on my wall and it stains our clothes
the brown liquid is rust from leaving the water in the iron. Always dump the water out when you are done ironing. You need to run a descaler through it. you can purchase descaler online. The shutting off and on could be a loose wire.
Aug 11, 2010 | Euro-Pro Shark GI490 Iron
I need to descale my iron Do I just fill and dial self clean?
There are number of commercial cleaners available. CLR is one of them. You can also use 50% vinegar and 50% water.
Pour the mixture into the water chamber and let the iron sit overnight. Switch on the iron the next day and put it on steam. Hold the iron over the sink. The dirt will come out of the holes on the sole plate. If the iron is badly scaled you may need to repeat the process or use CLR following the instructions on the bottle.
Using distilled water in the iron will eliminate or reduce the need to de-scale the iron.
Nov 16, 2009 | Irons
When using the steam it spits out sediment on the clothes. I have tried cleaning by holding the steam button.
This happens due to limescale and / or build ups of mineral deposits such as iron in the water. You will need to use a kettle descaling solution or an iron descaling solution available from most supermarkets or home appliiance stores and clean out the debris in the iron. It happens to most if not all irons and cleaning on a regular basis is the only answer or use very expensive 'iron water'
Sep 28, 2009 | Rowenta Powerglide DE011 Iron with Auto...
Rowenta steam iron no longer steams
Your local grocery or hardware store will sell "descaler" for coffee pots and irons.
Mix as instructed (water/descaler) and pour the disolved mix into the iron. Set the iron on the highest steam settings (heat and steam volume). After it is hot, let it steam into the sink, pressing the steam button over and over to let the descaler work through all the tubes/passages, until it has all been pumped out.
Refill with more descaler (if it is not completely unplugged) and repeat until you are satisifed with how the iron is working.
After descaling, run clean water through it with the same process (but no descaler) several times.
aymloekh0fg4hpz2e87n86udvs4fowqwshuaaaaasuvork5cyii=
Mar 24, 2009 | Rowenta Professional DE841 Iron
HOW DO I DESCALE A STEAM GENERATOR IRON
Place the iron soleplate, unplugged of course, in a shallow dish of water and descaler and leave it for a while. I have just done this with mine and its working a treat.
Dec 19, 2008 | Maytag MLI7500A Iron
Irons Logo
348 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
