Question about Toshiba 32HF73 32" TV
The remote control no longer operates the television. The same is true for any remote.
  • 10,594 Answers
Your question shows its Toshiba 32HF73 TV that has problem no operation with remote.
As you said no other remote work on TV including TV remote. That shows Infra Red Remote Sensor built in TV got defective and need to replaced.
Though IR Sensor replacement is job of qualified TV tech, and if you want to fix TV by yourself, you should have repair manual in hand, manual has exploded views, schematics and part number list etc that will help you to repair your TV.
You can download Toshiba 32HF73 repair manual from HERE for small fee. Required IR sensor (remote control receiver) is available in Part Store.
Thanks.
Posted on Jul 31, 2009
Can you tell me the code for a veitech tv . I cannot find the code to programme the remote hope you can help ?
can you till the code 4 veltech tv two operate sky remote
www.justanswer.co.uk > TV
Question - can you till the code 4 veltech tv two operate sky remote - 2H. ... if you will rate me in a positive fashion before you close this page, the system will ...
Sky Digibox TV remote control codes for your television
www.satcure.co.uk/tech/digicode1.htm
Jump to How to get inside remote - If you warm the remote with a hair dryer, the plastic becomes more ... Please tell me if the link no longer works.
Jan 20, 2016 | Televison & Video
Why won't television turn on with remote control?
Check the remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 12, 2014 | Sanyo DP26640 LCD TV
Remote control issues
If you whsh to get all functions operated with your TV, you must have its original remote control, and it is no doubt. No universal remote control will operate with all functions, that are supposed to be, especially to Sony Brands. You can buy the original remote control from the authorized service center for Sony, or from any authorized dealer for Sony. Then why do you go for an experiment
May 14, 2013 | Sony Bravia KDL-32V4000 32 in. LCD TV
Remote No Longer Operates the BluRay Player
If you have tried battery removal and reinstallation/replacement it may be necessary to replace the remote
Nov 04, 2012 | Pioneer New Original VXX3379 Remote...
My toshiba 62hm84 was given to me without remote control. Can I operate it without it or do need to get a remote.
The remote control for this model is no longer available through Toshiba. You can operate the set but will not be able to use the picture size features. You should be able to work the main functions and also access the picture and audio on- screen adjustments. If you find a vendor that happens to have miscellaneous remotes, the remote number is CT90164.
I hope this helps,
Skyassoc
Dec 11, 2010 | Toshiba 62HMX84 62" Rear Projection HDTV
My television no longer accepts commands from the remote control. I have verified that the remote control works properly. Please advise.
Since remote control is verified so next thing involved in remote operation is remote sensor located on front of tv that receives remote signals.
Remote sensor seems defective in your tv and need to be replaced to solve remote issue.
Call local tv repairman if you have no experience of soldering parts in circuit board.
Thanks.
Oct 22, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
My GE Universal remote no longer works. The battery is fine but the signal is no longer working on my TV. I would like to try to reset the remote to my TV.
Please try to programme your GE remote to your TV
Manual code entry
1.Turn on your television or other electronic component that you want to program the remote control for.
2.Hold down the "Code Search" or "Setup" button until the LED indicator light turns on.
3.Hit the button for the component that you are programming (TV,DVD VCR, etc.). The LED light should flicker and stay on.
4.Enter the 3-digit or 4-digit code that corresponds to the TV or device that you're operating.The LED light should go off if the code is valid, but will flash if it is not. Try other codes you have.
5.Try turning the television or other programmed component off to ensure that the remote works properly, once the light has gone off.
Auto configuration
3.Hit the button for the component that you are programming (TV, DVD, VCR, etc.). The LED light should flicker and stay on.
4. Press and release the "Power" until the television or other component turns off while waiting at least 2 seconds between each press.
5.Press "Enter" or "Save" once the remote has effectively turned the power off. The LED light will shut off and the remote will now operate the device.
You can get your codes from below website
http://www.jascoproducts.com/support/universal-remote-codes.asp
Thanx
Aug 04, 2010 | GE RM24930 Remote Control
Factory Remote Control for Sylvania model SRT2319 doesn't work
You can buy an original replacement remote for your TV clicking the link below:
New Original Sylvania SRT2319 Remote Control $39.99
Apr 18, 2009 | Sylvania SRT2319 TV
Remote will no longer control the tv
Make sure the "TV" button is selected on the remote
Feb 11, 2009 | LG 50PX2DC 50 in. Plasma Television
Toshiba 32HF73 32" TV Logo
113 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
