Question about Dell Inspiron 2200 Notebook
How do i set up this comp. to show wireless connections
    President:
  • 1,383 Answers
Install wi fi network adapter driver.
Turn on wi fi switch it is on laptop you can find it easily.
Then you can see your wi fi network in my network places.
Posted on Jul 31, 2009
When I tpye in 192.168.0.1 always says page not available,
Yes connect your PC and Router with Ethernet cable and try again.
Your router's manual is here, refer it for reset your router, it's best idea to reset and whole solution. http://www.dlink.com/-/media/Consumer_Products/DIR/DIR%20655/Manuels/DIR655B1manual070312v23pdf.pdf
Sep 26, 2012 | D-Link DIR-655 Wireless Router
The red light is flashing and when i try to get on with wireless it shows full servise but will not pick it up
which light is flashing red, wireless, ethernet,or internet? Check settings on computer. It does not sound like a modem problem. If you have another computer, see if it connects or if it has same problem. Configure wireless settings on comp.
Feb 03, 2011 | 2wire (1000-000057-000) Modem
Actually, im just unistalled my pc's wireless network adapter, the problem is,.. i dont know how to install it again,. i cant connect to any wireless network,.
Simply go ahead and restore your comp to a back date.
Click on start, all programmes, accessories, system tools, system restore.
Select a bold date with description showing check point.
Click on restore.
Once restore is completed successfully the driver shud be back on the comp.
And u shud restore it to the date before u uninstalled it from ur comp.
Jun 05, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
Comp will not connect to internet and tells us there is a cable not connected. It is wireless and the modem is working with all other comps in house. I have checked the modem, switched it off and...
have you installewd the drivers for the modem ? if you have go to desktop and click settings got to network settings open this up it should show any connected networks if not click new connection then go throught the proceedure you can try the first internet connection if not try the advanced option for the wireless.. make sure you installed the wireless drivers as well a it wont work without these.. Good Luck A
Jun 30, 2009 | Advent Netbook
Two laptop connected to wireless router. comp1 can access files from comp2 but comp2 cant access files from comp1. both comps show network map and can get ip yet comp2 keeps timing out when attempting...
Considering that you are using both comp with dynamic IP and from same wireless roughter and OS is same from both laptop.
As you are able to ping from comp1 to comp2 and not able to ping from comp2 to comp1 .. check the firewall setting of comp1 or disable the firewall from comp1.
Aug 23, 2008 | Computers & Internet
Wireless connection
Your wireless set up for super G ? So i think the first problem is configuration e standard mode for wireless. Set up only 54 g.
Second search for your factory wireless usb new driver for windows vista.
Good Luck.
Mar 27, 2008 | Belkin (F5D5231-4) Router
Wired one
if you are not able to connect through your main comp using wireless router...then first of all check the ipaddress of computer by..
start>run>type cmd>then type ipconfig in command prompt screen.check whether you get the ip address as 192.168...........and default gateway as 192.168........
if anything else reinstall nic card on your comp
Feb 16, 2008 | D-Link AirPlus DI-524 Wireless Router
Security
Till the time you put a access code for the wireles it would show it as a unsecure connection.You can change this by accessing the router page.Just type 192.168.1.1 in the address bar of internet explorer.Than it would ask you for username and password.Its ussually admin and the password field blank.Than go to wireless settings and the security to WEP.than you can put a password of either 5 or 10 digits.U can put your phone # which would be easy to remember and than just save the setting.Next time when you would try to connet to it than it would ask you to put the access code and will show up as secure connection.
I hope that helps
Dec 25, 2007 | Linksys A+G WRT55AG Wireless Router
Xoom x6 adsl modem problem
possible issue with freequent connection loss when going over 2 comp on a network are possible issues of collisions on the network meaning that sometimes more often then not, it is possible for two comp to end up recieving same ip address fr modem.
solution: first find out ip range supplied by the router in modem. then statically assign ip address to each comp
this is done by going into tcp/ip properties of either nic or wireless card and set to use following ex
NOTE: IP RANGE USUALLY LAST SET OF NUMBERS IN IP ADDRESSING TIPPICAL RANGE IS BETWEEN 10 TO 99
ip address: 192.168.2.12 (static ip address for computer)
subnetmask: 255.255.255.254 (generic subnetmask)
default gateway: 192.168.2.1 (ip address of router)
Oct 18, 2007 | Zoom X6 (5590) DSL Modem (55900003)
Dell Inspiron 2200 Notebook Logo
179 people viewed this question
Alun Cox
