Question about Tyco Electronics / Raychem T208M-Printer
I type in what i want to print on tyco T508M, but what it prints is nothing like what i typed and on bottom left hand corner i get a ine with 3 squares
    President:
  • 2,976 Answers
Check the manual for the settings. You must have the correct conversion from what you type to what it will print.
Posted on Jul 31, 2009
On some pages ,at the top of the page there is the word print and it allow youto acess your printer ,other places on the computer ther is no word printer ,how do I acess my printer?
In the upper Left-hand corner of your browser scrreen, Click on "File" (or type ALT-f) to get the
File drop-down menu.
Then select one of the 3 printing options:
1) Page setup
2) Print Preview
3) Print (Ctrl-P)
Alternatively, you could just type Ctrl-P (by holding down the "Ctrl" key then pressing "p")
whenever you want to print the current page.
Aug 17, 2011 | Computers & Internet
My printer -X1185 prints the page with a 3 inch blank area on the left side and some of the right side printing is off the page. This is typical in my e mail page, and even if I center the letter on...
Web site designers create Web pages for display on a monitor, not for users to print on 8.5- x 11-inch pieces of paper. This becomes obvious the first time you try to print a Web page. Content you need may get chopped off by the right printer margin, whereas content you don’t need, such as the site’s copyright information, will print on its own sheet of paper. Fortunately, you can avoid such problems with a little foresight.
Before printing any Web page, open Internet Explorer’s File menu and select Print Preview. The current Web page will appear on-screen exactly as it will print on paper. Scan the preview carefully. If it appears that some content is chopped off by the right margin, click the Page Setup button located directly to the right of the Print button in the upper-left corner of the Print Preview window. In the resulting Page Setup dialog box, adjust the left and right margins so that each is set to 0.25 inches. The extra inch of space you gain by resetting the margins should provide just enough room to accommodate all of the content on most sites. Click OK to save the changes and return to the Print Preview window.
Next, scan the preview to determine which pages contain the content you want to print. Take note of those pages and click the Print button in the upper-left corner of the Print Preview window. Locate the Print Range heading and select the Pages option. Type the number of the first page you want to print in the From field and type the number of the last page you want to print in the To field. For instance, if you want to print just the first three pages of a Web page’s content, type 1 in the From field and type 3 in the To field. If your browser doesn’t have To and From fields, type the range of pages (such as 1-3) in the corresponding field. Make sure your printer has paper and click Print.
May 04, 2008 | Office Equipment & Supplies
HOW TO TAKE BROTHER PRINTER OFF OF MANUAL FEED OPTION
Hi there!
The message that ask you to manually feed the paper will appear if you have recently printed on a different type of media.
Does this happen from only one application like Microsoft Word? If it does try printing a test page or a document from other application like Notepad or Wordpad.
If the same issue occurs go to the Printers folder (under control panel) then right click on your Brother printer icon, left click on Properties, click on Printing Preferences and make sure that Tray 1 is selected for the tray, Plain paper for paper type. If changes have been made make sure to click on the apply button to apply the changes.
If it only happens to one application like Microsoft Word. Click on File ( or the orb icon on the upper left hand corner) then Print, then Print again click on Printing Preferences and make sure Tray 1 is selected and Plain Paper.
Hope this helps! Thanks
Jun 09, 2011 | Brother MFC-7820N Laser Printer
What does it mean that printer is on "pause"
This means that print jobs sent to the printer will not print untill the printer is unpaused. This setting is used mainly for maintenance purposes.
To unpause a printer
1.) Left click Start in the bottom left hand corner of the screen
2.) Left click Control Panel
3.) Now, double-click "Devices and Printers" or "Printers and Faxes"
4.) In the Window you will see your printer, double-click your printer
5.) This screen will show you active print jobs, to pause or unpause the printer click File then click "Pause printing"
Hope this helps :)
May 15, 2011 | Epson Stylus C66 Inkjet Printer
Check error
Try the following steps
1. Unplug power
2. USING THE FINGER HOLDS ON EITHER SIDE, lock scanner cover into open position
DO NOT TOUCH THE ENCODER STRIP (clear plastic strip in front of the white vinyl band)
3. Remove jammed paper/foreign objects (check under the print head; if the print head is in the middle, slide it to the either the left or the right side, & check for paper scraps underneath the print head)
[IF WHEN THE SCANNER COVER WAS OPENED, THE PRINT HEAD IS ON THE LEFT SIDE]
4. Move the print head to the middle
5. With the print head in the middle, remove any ripped paper/foreign objects from the left corner (SINCE THE RIPPED PAPER COULD BE VERY SMALL, USE A FLASHLIGHT TO INSPECT)
6. Close the scanner cover & plug the machine back into the power outlet
[PERSISTENCE OF THIS ERROR MESSAGE OR NO PAPER SCRAPS/FOREIGN OBJECTS FOUND MEANS THAT THE ENCODER STRIP WILL REQUIRE CLEANING]
[IF WHEN THE SCANNER COVER WAS OPENED, THE PRINT HEAD IS ON THE RIGHT SIDE]
7. Plug the power cord back into the power outlet...LCD will show "Cover is Open"
8. Press Stop/Exit for approximately 5 seconds until the print head moves to the middle
9. UNPLUG MACHINE FROM POWER OUTLET
10. USE A FLASHLIGHT & TWEEZERS TO INSPECT: Remove any debris from the right corner
11. USING THE FINGER HOLDS ON EITHER SIDE, close scanner cover & plug machine into power outlet
TO CLEAN THE ENCODER STRIP... (clear plastic strip in front of the white vinyl band)
[Markings & debris can adhere on the surface of encoder strip FROM HAND CONTACT &/OR GREASE CONTACT INCURRED FROM REMOVAL OF JAMMED PAPER]
DO NOT USE FLAMMABLE SUBSTANCES NOR ANY TYPE OF SPRAY TO CLEAN INSIDE/OUTSIDE MACHINE
1. Unplug machine from power outlet
3. Clean both sides of encoder WITH ONLY A DRY, LINT-FREE CLOTH
DO NOT FORCEFULLY PULL ON ENCODER STRIP
DO NOT TOUCH ENCODER STRIP WITH BARE HANDS
DO NOT FORCEFULLY SCRUB ENCODER STRIP (THAT COULD SCRATCH ITS SURFACE)
4. Clean encoder strip from right to left--stopping just before the left corner
5. Clean encoder strip from left to right--stopping just before the right corner
6. Repeat steps 5 & 6 two or three times to clean thoroughly
7. After cleaning encoder strip, USE FINGER HOLDS TO close scanner cover
8. Plug machine back into power outlet.
Nov 29, 2010 | Brother M 4318 Matrix Printer
I need help to install this program
Hello Cryspycritte, Thank you for the clarification. Your program is definitely compatible with Windows XP. What you will need to do is put Disc 1 of Print Workshop into your CD drive. Click on your start button in the lower left hand corner of your desktop, then click run (located right above the "turn off computer" button.) A run box will appear in the bottom left hand corner. In the box type: D:\setup.exe (where D is the letter of your cdrom.) A setup window will appear with the final steps for installation. If you have any installation issues please post a reply. Thanks for using FixYa! Edward
Aug 24, 2010 | ValuSoft Print Workshop 2003 for PC
Broken hinge
TIP: Go to the web and type www.partselect.com enter your model number then scoll down to your part. Click to enlarge exploded diagram on left. Veiw enlarged diagram at top of page. You can print the entire diagram for exact assembly by holding your pointer in the upper left hand corner of diagram. Select the print icon. Now you have what you need. The lower hinge attaches the same as the top. If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 26, 2009 | Frigidaire PLMV169DC Microwave Oven
WHERE IS THE FUSE AT
TIP: Go to the web and type www.partselect.com enter your model number then scoll down to your part FUSE click to enlarge exploded diagram on left. Veiw enlarged diagram at top of page. You can print the entire diagram for exact assembly by holding your pointer in the upper left hand corner of diagram. Select the print icon. Now you have what you need. If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 26, 2009 | Microwave Ovens
Won't print to printer - sends to a screen to save
Hi, I don't know if you've had an answer to this one yet, but when you ask your 'puter to print. The printing window that comes up, where you can choose number of copies etc, has a little tick box in the bottom (I think left hand) corner, that says print to file. If you uncheck the box, hopefully this will sort out your problem.
Mar 21, 2008 | HP PhotoSmart C4280 Laser Printer
Envelope Printing on HP 5610
Installed SR-3 from Office Word. It did the trick.
Mar 10, 2008 | HP Officejet 5610 All-In-One InkJet...
Tyco Electronics / Raychem T208M-Printer Logo
198 people viewed this question
Top Tyco Office Equipment & Supplies Experts
k24674
Are you a Tyco Office Equipment and Supply Expert? Answer questions, earn points and help others
