Question about JBL Power P1022 Subwoofer - 10" Dual 2 Ohms Kevlar Paper Cone Plus One Cone Butyl Rubber Surroun... Car Speaker
Finding the best amplifier
I have a 2000 Hyundai Tiburon and i just bought a JBL 1600 watt subwoofer . My question is which amplifier should I use to get the max.performance ?
  • 655 Answers
Hello sharky75,
That 1600 watt peak power figure for your subwoofer can't tell you what amp you need. You need to know the maximum RMS power the sub can handle. And you need to know the impedance (ohms) of the voice coil(s). JBL GT5 series subs have an RMS rating of 275 watts. The GTO series handles 300 watts. The Power series handles 400 watts. The GTi series handles 700 watts. Some are single voice coil, so the impedance is fixed. Others are dual voice coil allowing you to wire them for different impedance loads.
For maximum performance your amp should be able to provide at or near the same number of watts RMS into the lowest impedance at which the sub can be configured. For example, if your sub is the Power Series Model number P1224, it has dual 4ohm voice coils and can be wired to present either a 2ohm load (parallel) or an 8ohm load (series). You want to wire the voice coils in parallel for the 2ohm load and select an amp that outputs up to 400 watts RMS into 2ohms. The Orion Cobalt CO8001 is just such an amp. If you have one of the GTi Series subs, a better amp would be the JVC Arsenal KS-AR75 which outputs 700 watts into 2ohms.
Hope this helps.
Posted on Jul 31, 2009
Car amplifier stopped working.
what gauge wire are you using
Apr 24, 2012 | Car Audio & Video
I have JBL GT5-S644 ,4chnnel,800 watts, bridgeable car amplifier.Is it possible to pair this amp with 2 pioneer 900 watts subwoofers working with 12 volt adapter at 80 amps in 240 volt in home ?
Hello
yes it is possible but you will find that the amp is going to be under powered to drive all three subs, will have to look at getting a stronger amp later. hope you enjoy rattling the house apart.
Enjoy
May 25, 2011 | Car Audio & Video
If i have a 4 channel 2000 watt amp, can i use 1600 watt wires if i only have 2 subs hooked up to it?
Yes, you will be fine. 4 gauge power wire is sufficient for a couple of reasons, the primary one being that most of the companies that are boasting 2000 watts for a 4 channel amp are off brand "web-retail only" companies, and they severely over rate the power output of their amplifiers. Secondly the supposed 2000 watts is peak power and not rms power. Peak power means how much power that amp can put out during absolue climax of the music or during a tone burst. RMS power is how much that amp will put out continously to your speakers or in this case, your subs. If you look at the spec sheet of that amp, in all actuallity you're probably only getting 200-300 watts rms even bridged.
On a side note, if you really want to push your subs hard, you might want to consider getting a mono block or "class d" amplifier and use that 4 channel amp to push your surround speakers. Class d/mono block amps are specifically designed to push subwoofers and will give you the most efficient power out and the best heat dissipation to withstand the output required to drive subwoofers. You'll get better bass and also more adjustability to tweak the sound levels coming out of your subs. Hope that helps.
Apr 02, 2011 | Car Audio & Video
I had Rockford Fosgate P300-1 Amplifier installed professionally with a Kicker CVR10 10 in Subwoofer in 2010 Comaro. My problem is that it causes an odor in my car. I took it back to Mothers window tint...
your kicker cvr subwoofer should have a max power of 1600 watts therefore your amp is not too much for the sub because the p300-1 amplifier has a max output of 900 watts. if anything your amp would not be enough to produce max power out of your subwoofer. your sub should not produce an odor unless you have your amplifier bridged which doubles the watts pushed to your subwoofer and if that is the case your amp is pushing 1800 watts to a 1600 watt sub which could be causing it to fry or possibly blow soon. other than that if thats not the case there shouldnt be a problem.
Dec 31, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
How i wire my sub to my jbl gto301-1iiamp with 2 Hifonics HFi12D4
If the amp is 1200 watts at 2 ohm stable you will want to set up the speakers as parrallel and bridge the amp. That means conncect the speakers with + to + and - to -. Look at the amp connections. Usually thereare connects that look like this:
If yours look like this use the diagram on top. You will use the + for the left ouput on the amp to the right - on the amp. This will allow you to use all the power from the amp. Be sure to lower the gain as to not pop the speakers or amp.
Nov 17, 2009 | JBL GTO 301.1II Subwoofer Mono Amp - 200W...
Best car amplifier
I've got a boss 1600 watt 4 channel amp ,720rms watts. up for auction on ebay right now that would work great. brand new in box. check it out. http://shop.ebay.com/?_from=R40&_trksid=p3984.m38.l1313&_nkw=boss+1600w+amp+4+channel+with+level+remote&_sacat=See-All-Categories
Oct 05, 2009 | Cars & Trucks
What would be the best amp for my 2 12''kenwood w3514 dvc 1600
Your sound system requires a 3000w amp. The best value for money amp I can find to help you is on ebay.Follow this link - current price is £149 http://cgi.ebay.co.uk/NEW-3000-W-WATT-1-CHANNEL-CAR-AUDIO-POWER-AMPLIFIER-2-4_W0QQitemZ260408043705QQcmdZViewItemQQimsxZ20090511?IMSfp=TL090511131001r33597
Jun 03, 2009 | Kenwood KFC-W3514DVC Car Subwoofer
Amplifier and subwoofer
Yes, it should have little trouble. You will be best to keep it 2-channel and get another Sub. then run both. if you bridge it you will blow your 1 Sub. DON'T FORGET to put a in-line Low Pass Crossover in front of the Amp. OR any Sub.(one for each if you do go for 2) as they were never made for the high frequencies. An adjustable one is best for fine tuning. In thory you have a 600 watts buffer that way. If you do it Mono you are 400 watts over. If you want to go Mono you will need over 2000 watts on the Sub. end to turn it right up. Oh and some good ear-plugs if you want it loud whilst you are inside the car.
Dec 26, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Car Audio & Video Logo
187 people viewed this question
Top JBL Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
isaac johny
isaac johny
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
