Question about Eaton Corporation GFCB115 GFI Circuit Breaker
I turned it off for about six months, now it will not reset. There are no loads applied.
  • David Shaub May 11, 2010
    Make sure it's on a live circuit.
  • 398 Answers
You must push it kind of hard to get it to reset. first kill the 100 anp or 200 amp breaker. that is what most of sizes used now days. it will be the big wide breaker. now pull the wire our of your eaton breaker. if it has 2 wires pull them both. it has just one pull it. move it back where you wont touch it or it wont touch anything else. now reset it again. it it resets you have a bad short down the line. let me know and i will help you run it down. good luck and good day. sawdust46
Posted on Jul 31, 2009
How do you unlock the control panel so the " AF " code can be reset ?
After six (6) months of use, the display will show AF. This is a reminder that it is time to change the air filter. The product will continue to function normally. Pressing any key will reset the reminder for 10 minutes. Once the air filter is replaced, pressing the "On/Off" and "-" keys for three (3) seconds will reset the reminder for another six (6) months.
Apr 01, 2016 | Electrolux EI24WC65GS 24" Under-Counter...
After working well for six months, my washer now expels water at random points during the wash and rinse cycles.
Check inside the fill hose for debris. There is a screen designed to block debris from getting inside the machine valve. If the screen builds up with debris the water slows down. Sounds like the water is filling too slow. Also the unit and/or the load may not be balanced causing it to stop and drain out. If it's okay then see what lights are blinking when these events occur and post here.
Jun 06, 2013 | Haier HLP21E Top Load Washer
Where is the filter on my rs2630
Removing and replacing a water filter - inside liner location
Filters situated in the interior liner of the refrigerator compartment of Samsung-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  1. Grasp the filter and make a one quarter turn to the left. There should be an indicator line located on the filter bracket cover. The install mark on the filter itself will line up with this indicator line.
  2. Pull down gently on the filter to remove it from the mounting bracket assembly. Be careful to not tip the filter, as water may spill out of it.
  3. Discard the used filter.
  4. Remove the new filter from its packaging, and remove the red plastic cap from filter cartridge.
  5. Apply the appropriate month sticker to the filter to remind yourself to change it again in six months' time.
  6. Line the install mark on the filter up with the indicator line found on the filter bracket cover. Push up on the filter. Turn the filter a quarter turn to the right to lock it in place. The remove mark on the filter should line up with the indicator line of the filter bracket cover.
Note: Replacing this type of filter is quick - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Aug 19, 2011 | Samsung RS2630WW Side by Side Refrigerator
Who do you reset change oil soon light on a 2009 f350
To reset the oil monitoring system to 100% after each oil change
(approximately 7,500 miles [12,000 km] or six months) perform the
following:
1. Press and release the
SELECT/RESET button to display
“OIL LIFE XXX% HOLD RESET =
NEW”.
2. Press and hold the
SELECT/RESET button for two
seconds and release. Oil life is set to
100% and “OIL LIFE SET TO 100%”
is displayed.
Note: To change oil life 100% miles value from 7,500 miles (12,000 km)
or six months to another value, proceed to Step 3.
3. Once “OIL LIFE SET TO XXX%” is displayed, release and press the
SELECT/RESET button to change the oil life start value. Each release
and press will reduce the value by 10%.
Sep 30, 2009 | 2008 Ford F-350
My JXD PMP is dead since six months. When i power
i am also having this proablem from 6 months
Jun 12, 2009 | Audio Players & Recorders
Error Code F22
loose connection or mother board again
Jun 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Stops working, but music still on
TRY CLEANING YOUR LASER LENS with canned air and clean the rubber surface of the drive motor with rubbing alcohol applied to a microfiber towel this reqires removal of the cover
Jan 11, 2008 | Sony PlayStation 2 (PS2) Console
Hanging
Do you think you could provoke a hard reset by leaving the battery out overnight?
Sep 08, 2005 | HP iPAQ RX3715 Pocket PC
Eaton Corporation GFCB115 GFI Circuit Breaker Logo
159 people viewed this question
Top Eaton Electrical Supplies Experts
john h
T-Comtech Repairs
T-Comtech Repairs
Are you an Eaton Electrical Supply Expert? Answer questions, earn points and help others
