SOURCE: Kenmore front load washer won't start. Lights just blink
I had same problem........push options and select button at same time, hold for 5 sec.......choose option.....machine stuck inbetween cycles.
at least it worked for me!
SOURCE: blinking lights
I left if off and unplugged for a few hours. When I plugged it in it started working again. My recommendation if this happens to you is to just unplug it all and let it stand for at least 4 hours and then plug it back in.
Good Luck
SOURCE: how to sync drums to wii rb2
If you look on the USB Dongle. If there is a blinking LED that means the Dongle lost connection with the drums. Hit the Black button and all should be fine.
SOURCE: All lights on Dualshock 3 blink 5 times, then do nothing.
On the back of you dualshock pad next to the L2 button there is a tiny small hole witch looks like it could be a screw hole ! well this is the reset button once you have pushed this you will be able to conect your pad to your usb cable and it work on your console again
SOURCE: Dishwasher won't start. The Quick Rinse light is
The light blinking indicates that the program is ready to start but has not received the go signal from the Start / Stop b utton as the switch is probably faulty.
Try to reset the machine by disconnecting the mains power, waiting at least 10 seconds and then reconnecting. Try to start the machine in the normal way and if it still will not start then it means that the switck control is faulty or the control unit has a fault.
Yo will probably have to call a dishwasher technician to rectify the problem.
