A
Anonymous Posted on Mar 20, 2018
Ibought Sony FB-120 mic, I tried to connect it to my home theatre, but after connecting it to the system, it says do setup, i did it but still it shows the setup screen again after I reconnect it.
After I connected it into the port, it says to complete the setup, after doing the setup then say press OK and save, Then they say disconnect the mic, after doing so they make me do the setup again when I connect the mic, plz help! I have a Yamaha system wth Bose speakers
5 Related Answers
Anonymous
  • Posted on Nov 01, 2008
SOURCE: How do I connect my laptop to my home theatre system?
The best idea would be to get an audio interface, providing that your home theatre has an IN such as left and right phono. hese can be found for around 60 GBP. A chaeper alternative would be to buy and adapter which splits headphone to phono although an audio interface would allow you to send sound from you theatre in to your laptop as well.
guy cloutier
  • 10 Answers
  • Posted on Jan 19, 2009
SOURCE: Connecting rear Wireless Speakers on Panasonic Home Theatre Kit
Hi
Just push and hold the fast forward button on your receiver and push the button number 3 on your remote simultanously
your unit cames in pairing mode a P appear in the display
after, goes to your wireless receiver and push the reset button on the back
normally after that the unit must connect with your receiver
Anonymous
  • 8546 Answers
  • Posted on Apr 13, 2009
SOURCE: how to connect bose 901 speakers to 5.1 setup?
The solution is simple and cheaper than you think.
The analog 5.1, 6.1, 7.1 outputs on your receiver should be active even with digital inputs that you want to hear. Your receiver turns everything it processes into analog output just before the speakers anyway so there's no loss of access to multichannel sound this way.
What I did was to buy a separate amp for the 901's and feed the Front L&R analog audio out to the EQ which is directly in front of the amp. The Active EQ is only for the 901's which don't have woofers or tweeters so Bose flattened out its final response electronically with some serious boosting at both ends. Having it in line with any other speakers would feed them a grossly over-compensated signal.
Your receiver will drive the rest of the speakers.
This is the cheapest way to have your 901's and hear them, too. Since the 901's are really efficient you don't have to buy a big amp that would heat the room. I'm using a separate Carver amp with 2x100w for mine.
Anonymous
  • Posted on May 03, 2009
SOURCE: Bose link AL8 connection problems
I had a similar problem, though intermittent, using my 48 with the AL8 and room-mate speakers. I kept getting a "no signal received from media centre" message on the remote in the second room.
Assuming that the batteries are ok and you don't have a hardware problem, the problem might be that the 48 is not picking up the signal from your remote control in your second room. The signal from your remote control is a radio signal that goes directly to the 48 - it doesn't communicate via the AL8 receiver. I think the orange light will only turn green once a signal is being transmitted from the transmitter unit plugged into your 48 media centre, and this won't start transmitting until the media centre gets a signal from the remote telling it to switch on.
The aerial for all the remote controls is contained in the power cable that links the 48 lifestyle unit to your VS-2 unit. Make sure that this is uncoiled and oriented vertically, as far away from other cables as possible.
If this doesn't work, you can get an antenna extender that plugs into the RC socket on the back of the lifestyle system. Again, orient this vertically. You can get these from Bose.
Is there anything in the wall that might be blocking the radio signal? Lots of metalwork for example?
If orienting the power cable from the VS-2 doesn't do the trick, I suggest that you go to a local Bose shop. (An actual Bose shop, not just an electrical or hifi store stocking Bose products). I explained my problem and the tech guy gave me an extender gratis (its basically just an FM aerial wire by the look of it). I installed it this morning and, so far, its seems to be working ok. As my unit is fairly new, he also offered to have the kit back in the shop to check it all out and, if that didn't work gave me Bose technical support number. He even offered, if all else failed, to send a guy out to my home to get it working - and I didn't even buy it from there!
Hope this helps.
Anonymous
  • 8 Answers
  • Posted on Sep 12, 2009
SOURCE: connecting bose 321 system to lg hd flat screen,bose receiver plays fm am ok threw speakers.tv will not play threw bose speakers.bose dvd plays sound ,but no picture
You will need a Component Video Cable
Connect the Red Green and Blue Connections from the TV to the Bose.
if your audio is coming from the TV, also connect stereo audio from the TV's audio out to the "TV" input on the bose.
if you want to hook up other devices (VCR, BluRay, etc) the video will go directly to the TV and audio will go directly to the Bose
Set won't turn on. Was working fine last evening. Now nothing.
Reciever RCA RT2500 ' Techlore
www.techlore.com/forum/thread/11889/reciever-rca-rt2500
Aug 20, 2005 - 31 posts - ‎23 authors
hey ive got the rca RT2500 home theater system. .... won't power up) regardless of number of times I try to simulate a 120 V power flash (pulling plug .... My RCA receiverturns on but there is no sound...what can this mean?
Trouble getting sound from home theatre system with my ...
www.tomsguide.com/.../trouble-sound-home-theatre-system-appreciated....
Mar 27, 2013 - TV: Sony Bravia KDL-60EX645 Home Theatre System:RCA RT2906 ...-I've set the television, per the manual's instruction, to "Audio System" and "Audio Out: Fixed." This should allow the TV to turn off its internal speakers and switch .... SolvedI have F & D home theatre system, my rear speakers won't work.
Problems connecting surround sound to LCD TV... - Forums - CNET
www.cnet.com > Forums > TVs & Home Theaters
CNETJul 30, 2006 - Hey I have a 26" LCD TV from Polaroid and a Philips DVD home theatersystem. ... the Audio setup on the tv and TELL it to output the sound via the RCAcables ... However, you would normally turn off the TV speakers with a menu ... I just can't figure out why the TV audio won't play on the surround sound. Anynet+ - Home theater won't turn on with tv
Jun 11, 2015
TV won't turn on
Jun 10, 2015
Audio Return Channel Problem
Aug 23, 2011
rca tv no sound?????
Jan 1, 2006
More results from www.cnet.com
How do I attach sony w60b to sonny DAV-HDZ 284 DVD Home Theatre System?
You can use the Component Video, composite video or HDMI connections to connect the DVD home theatre system to the TV.
See the manuals on this site.
DVD Home Theater System
16helpful
How do i connect a nintento wii to my sony home theatre system model htsf 470?
Hi beejaysaunde,
To connect your Wii to the htsf 470:
1. Connect your Wii to your TV.
2. Use a separate audio cable (red/white) and connect from your TV to your htsf 470.
3. Choose the correct selection on the htsf 470.
This setup will have your Wii's video go directly to your TV and the Wii's audio to be sent to the stsf470.
I hope this helps.
Hi I have the Sony DAV-HDX285 home theatre system and I'm trying to get it to work with my Vizio 47" HD tv. I go thru the speaker setup with the dvd supplied and all speakers are working tthu the home...
I assume you mean the TV sound only comes out of the TV. THAT would involve internal audio controls at the TV.
Why don't you just connect the TV-related audio directly from each source to the DAV instead of through the TV, which adds NOTHING to the sound quality and may even degrade or limit it.
How to connect Panasonic DMR-EZ25EB to KEF KIT 120
OK for some odd reason I never noticed that this was a reghurgitated question
BUT hey
The only way to really do what you want is to insert an AUTO HDMI switch to the AV1 and go from there.
http://www.monoprice.com/products/subdepartment.asp?c_id=101&cp_id=10110
Have a selection
Connection/sound issues!
the best thing to do is if ur lcd has a phono in/out is to connect ur theatre system through phono straight to the tv as then everything that comes up on the tv comes throught the theatre system
How do I connect Sharp XR-10XL projector audio output to a Sony Home Theatre System DDW795?
Dear Sir,
Pls take The output from the projector in the stereo format and connect thru thru the approriate cable to your Sony Home Theatre System DDW795 on audio input.
Virender Dhiman
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
