Question about Craftsman Garden
New sparkplug fresh gas does not spark will not start
Cleaned filter
    Problem Solver:
  • 13 Answers
Check flywheel key. Replace if damaged at all.
Posted on Jul 31, 2009
Miller Bobcat 225G was sitting for about a year I put new gas new fuel filter new sparkplugs and cleaned out the carb it cranks good but wont start I have no spark to the spark plugs
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Mar 08, 2017 | Bobcat Garden
New spark plug, fresh gas, clean air filter. Wont start.
take the fuel line off at the carburetor. if fuel is coming out then you have a plugged carburetor. take it off and apart. clean it really good with carburetor cleaner and put in a new needle and seat. it should run as good as new.
Apr 30, 2016 | Garden
It doesn't start
Start by checking these:
Fresh gas,
clean air filter,
gasoline shut off valve open or on,
no shorting / engine stop wire on spark plug wire,
remove and clean or replace with new spark plug.
Jul 28, 2015 | Garden
2006predator 90 won't start new carb new stater
New carb, starter, air filter, and new plug. The question is do you have spark, and did you empty old gas out of tank before you installed the new carb . You may have some water that went from tank into new carb. You won't start. GOOD LUCK FRIEND.
Sep 14, 2014 | Garden
17 hp briggs stratton ohc
Clean or change air filter. Clean, gap or change spark plug. Empty gas tank add fresh gas with Stabil. When spark plug is removed pull rope several times to blow out cylinder. Spray starter fluid in spark plug hole before replacing spark plug. Clean outside of carb so choke works freely. Spray starter fluid into carb breather hole with air filter removed and try to start. if running replace air filter and cover. If no start disassemble carb and clean. If no start replace carb.
Jun 19, 2013 | Garden
MY MOWER WILL TURN OVER BUT IT WILL NOT START
if you spark a little starting fluid to it does it fire?if so then fuel is the problem then is the gas older than 30 days dump it out and try fresh gas if new gas then open the carb and clean it if it does not fire on starting fluid check for spark if no spark pull the top cover from the engine and look for wiring damage unplug the coil from the engine side of the coil and check for spark if no spark then the coil is bad and if its a riding mower the carb might have a anti back fire valve that could stick closed
Apr 27, 2012 | Garden
Lawn mower will not start
check gas tank with light is there dirt in tank? did you change fuel filter? is there spark at the spark plug? try a 2 second spurt of starting fluid in carburetor and crank does it fire?if it does then you most likely need to clean carburetor with carburetor cleaning spray, flush fuel lines with spray and swap fuel filter.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Kawasaki KRB750 B: Won't start. Have spark,
Check your off/on switch you can test it with an ohm meter to see if you are getting a open curcuit
Mar 12, 2010 | kawasaki Krb750b Backpack Leaf Blower
Willnot start
Check and,or; replace your fuel filter
May 20, 2009 | Homelite 'Yard Broom' Leaf Blower
Yard Machine MTD push lawn mower won't start
Sounds like you need a complete tuneup. Start with the carb. then clean all coil contacts, air filter and this will start you in the right direction. Good luck.
Mar 24, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
56 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
