Question about Delphi MyFi SA10113 XM Radio Receiver with Home and Car Kit
MyFi remote control has stopped working
My remote for my Myfi reciever has stopped working. It worked fine for several months and then stopped. Changing batteries does not work.
Any help?
    Problem Solver:
  • 14 Answers
Ok take the battery out of the radio then put it back in and it should work mine did the same thing to me
Posted on Feb 01, 2008
I had the same problem. This procedure from the "Technical Questions" section of worked for me:
"My MyFi won't power up, how do I reset it?
To reset your MyFi, start by turning the receiver off and removing it from its (car, home, audio system) cradle. Then remove the back cover and battery. Using a small paperclip, press the reset button located on the top left corner of the battery compartment. Now plug the AC power adapter into a wall outlet and plug the power port directly into the bottom of the MyFi (battery stays removed). Wait 10 seconds and listen for a beep. After you hear the beep the message "insert battery" will appear. Cycle the MyFi to ensure it powers up and powers down. If the power cycle is normal, then turn off the MyFi, unplug the power adapter, and reinstall the battery. Re-plug the AC power adapter directly into the bottom of the MyFi. Wait 10 seconds and listen for a beep. After the beep you will see the message "battery charging". Leave the MyFi plugged in until it's fully charged. You will see the message "charging complete" displayed. After the MyFi is fully charged, turn it on and reset to the factory defaults. Unplug the MyFi from the AC power adapter and using the battery power leave it on until it fully discharges (approximately 2-5 hours). Plug the MyFi in using the AC power adapter to recharge the unit and resume normal use. If you need help at any point during this process contact us at 1-877-463-3574 for technical support."
I hope it works for you too.
Sep 27, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
I can't get my delphi myfi sm radio to work even when I use the AC adapter on the cradle. For a while, it would work and then go off by itself. Now, it won't even go on. What's the problem?
You should: Insert your MyFi into its home stand and plug the AC adapter into the wall to charge the battery.But if its really not charging a battery replacement is already needed for this unit and you can get the battery from a authorize service center.
Sep 11, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
My Delphi XM2GO MyFi has stopped transmitting to an FM station on a house radio. Is it repairable? If so, is there a facility in the Cleveland, OH area where I can take it?
IF you take it out of the home dock and run it on batteries, I'll bet you it works again. The newer home docks TURN OFF the FM transmitter. Try a car dock, or try it with just the power plug plugged into the bottom of the MyFi, without the home dock and see if you can now get the FM transmitter to work. Let me know. Thanks and good luck.
Aug 09, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
Bought new battery about a month ago, everything until last week. Now my MyFi will not power up. What can I do?
Pull the MyFi from the base and plug the power cable directly into the bottom of the SkyFi radio - you should be able to power up with it plugged in directly, even without any battery. Give it a try and let me know.
May 18, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
The dial on Delphi MyFi is no longer functioning. Can it be reapired and where? Thanks, Chris
Very common -happened to me; cheaper to use a remote control than to get it fixed, or even buy a next generation radio.
Jan 23, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
I have the Delphi MyFi xm2go. It is not the newer version, SA10113. My problem...It is no longer transmitting to my car's FM radio. While it is sitting in the cradle in the car, it 's display shows that it...
Make sure that this is NOT a "Sure Connect" version that has a very weak FM transmitter, but the older original model with a bland box. Make sure no earphone is plugged-in, then go to the menu and set the FM frequency and set the FM output level and you should be all set..
Jan 20, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
Antenna Error
ok i had the same problem with mine it was the power supply but i had mine in the house with the home kit hope this helps
Jul 23, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
try doing away with the external fm transmitter and use the one thats built in to the delphi you just go into settings and set it to a station that has no channels and tune it in
Jun 13, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
Delphi myfi xm2go
I have the same problem. I finally was able to get Delphi Tech Service and found out that these units have a flaw. they have been going out after about 14-18 months and there is no known repair... neither does Delphi offer a repair service for this problem.
Dec 17, 2007 | Delphi MyFi SA10113 XM Radio Receiver with...
My XM Delph MyFi won't "record"
I get the same problem once in a while. Try removing the back cover and hitting the reset button via a paper clip--then try accessing the stored content. The MyFi should "release" the stored content.
Dec 13, 2006 | Delphi MyFi SA10113 XM Radio Receiver with...
Delphi MyFi SA10113 XM Radio Receiver with Home and Car Kit Logo
185 people viewed this question
Top Delphi Audio Players & Recorders Experts
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
