SOURCE: How to reel in a fish
To reel out push on Z on the nunchuk and continue to rotate nunchuk or push on B and Z
SOURCE: How to remove fan cover
Hi, although mine is currently not working I was able to take the cover off by loosening the six screws that hold the front grill on - the screw heads are visible around the edge of the outer ring.
Good Luck
Keith
PS - there are then four (I think) which fasten the back grill to the motor
SOURCE: need to remove tailgate door panel on a 2006 ford freestar
Unscrew the two screws holding the handle on the bottom of the tailgate, then using a long screwdriver pry the clips loose on the inside holding the panel on. Replace in the same order.
SOURCE: Dust Cover will not come off a Mead EXT Astro Telescope
It is probably sticking because Meade use some adhesive backed pads to make the cover fit tightly. Mine jammed initially too.The tacky glue from these will stick the cover in place. Careful teasing of the cover with a broad blade screwdriver should persuade it loose, it is flexible plastic but go carefully.
After it is off peel off the pads and clean off the excess glue with WD40. Degrease the area and either replace the pads or add some of your own (DIY shops sell adhesive pads)
SOURCE: i have a 1991 grand caravan the right front half
Two things, if you get a vibration when you are decelerating( an indication of shaft problems) you may need to replace your 3 motor mounts. But more important, most aftermarket rebuilt shafts are junk. Buy only new or Mopar rebuilt axle shafts. Anything other than Mopar new shafts or Mopar rebuilt shafts(sometimes Mopar rebuilt can be bad too) and you are pretty much guarantying that you will be replacing the shaft again with in 6 months. I own a 1993 Voyager and have replaced a dozen axles. The problem stopped with the OEM parts. Forget about the lifetime warranty offered with auto store axles, unless you enjoy replacing axles.
