Question about Mackie SWA1501 Subwoofer
Volume reduction with same input ( 4 years old),
I purchased a used Mackie SWA1501 ( 4 years old, purchased 4/09). It tested fine before I purchased and have used several times with no problems. Recently something has happened, volume on the 1501 is much less with the same input level (gain knob on 1501 at 12:00). I must turn up to near full gain on the 1501 to get the same volume I had previously. I have checked input cords, etc. There is not noticeable speaker distortion or hum. I understand this amp has multiple internal fuses- could I have blown one and only be amplifying on half of the amp? I have green on power LED, the signal LED will flicker with input, LED for overload is not lit.
If it is a fuse- can I replace it my self? I am moderately skilled at simple electronic repair.
  • rhmarlow Jul 31, 2009
    I am using the same Mackie Mixer board with the same inputs ( mikes and Keyboard) set at the same level to feed the sub ( 1501). I have not put a volt meter on the signal but the inputs are near the the same signal level because I feed thru to two Mackie SRM350s which have not expericenced the same volume reduction.
Macie SWA1501 volume reduction problem posted on July 31,2009- Tried to follow your advice on pulling out the amp and finding the 5V and 12V regulator IC. I pulled out the amp and looke for over an hour and found no component with the number 7805 or 7812 on it. I took it to work, and have our electronic tech look it over with his high power lighted magnifying lens and he couldn't find them. I looked extensively for burned parts- none, bad solder connections- none, and any other sign of damage. The only thing I could find is light whitish corrosion on some of the solder connections- these I cleaded with fiber brush and contact cleaner? Any suggestions would be appreciated. R Marlow
Posted on Aug 06, 2009
  • 4,234 Answers
What are you using to feed the sub? Are you sure that the signal level you are presenting to the sub is the same?
Dan
Posted on Jul 31, 2009
  • ABRsvcs Jul 31, 2009
    Thanks for the update. The next step is to check the input control on the sub itself and the power supply. If you have lost the 5V supply, you will not get the initial pre-amp section boost and hte overall volume will be low. Check the board for poor solder connections at the 5V and 12V regulator ICs. These will be 3-legged parts that look like transistors that should be marked 7805 and 7812. If you have a meter and can turn on the unit while open safely, check the voltages to ground on each pin. You should see for the 7805 something like this: (>5V, 0V, and 5V) The >5 reading will likey be 12V or so. For the 7812 the readings will be similar, but greater than 12V and 12V rather than 5.
    Please check that and update this again.
    Thanks,
    Dan
Hi, I have a Mackie MR8 that isn't putting out sound anymore.
I assume that you switched L and R monitors to verify the problem and so I would say that you have a amplifier failure issue. Knowing Mackie, they're probably using an output IC for amplication which although it took some time, has now completely died.
Me being an old-timer I can honestly say....Oh how I miss the discrete transistor and "thru-hole" component mounting days.
Oct 24, 2012 | Mackie Mr8 Active 8" Powered Studio...
I own a Mackie CFX20. It isn't the MKII. The effects are very weak, and they buzz a little when you try to use them. How can I fix them, and is a service manual available?
I would spend some time with contact cleaner, apply it to the switch contacts of any 1/4 inch jacks, and all of the connectors to the effects boards- it will entail some disassembly. Check all chassis ground connections you may have one that is a bit loose, broken, or corroded.
The Mackie support downloads for manuals has 2 sections- you needed to look at the top at the "discontinued products" Where these are.
http://www.mackie.com/support/downloads/discontinued.html
http://www.mackie.com/pdf/cfx_om.pdf
http://www.mackie.com/pdf/cfxseries_ss.pdf
http://www.mackie.com/pdf/cfxseries_hu.pdf
http://www.mackie.com/de/pdf/CFXSeries_OM_German.pdf
Feb 21, 2012 | Music
How do you use the mixer with a regular combo amp and stereo mic cable?
This is not hard to do, but it will require some adapters. Hosa company makes adapters to accomplish this. For example, if your Stereo mic has "1/4 inch male phone plugs" Hosa makes and adapter that has 1/4 inch female plug to Male XLR connectors. The Mackie, and just about every mixer in the world these days has Female XLR connectors for it's microphone inputs. So that will handle tha.
I'm not sure what you mean by the "combo" amp. If it has XLR inputs you can use Tip Ring Sleve male output jacks to the output. If your amp as conventional 1/4 inch female input jacks. Than a simple
1/4 inch Male to Male Guitar Cable will work fine. DON'T USE A SPEAKER CABLE as it is uninsulated and you will get 60Hz hum.
I hope this helps,
That looks like a great quality mixer you have!
Happy New Year,
Mark
Jan 01, 2011 | Mackie 402vlz3 Mixer 402vlz3 402vlz3 Vlz...
Working fine for the last 20 years with my arcam delta 290 then whilst on my ps3 the av processor started to make a buzzing tone through all speakers. tried all the different modes, unplugged, checked...
In nearly all cases buzzing on audio equipment is caused by faulty leads or having leads in close proximity to EMF sources. Remove all the input and output leads, does the it still buzz. Connect the speaker leads, does it still buzz? Then connect the input leads one at a time. This should pinpoint where the problem is. If you find a faulty lead, swap it out for another, new quality lead that is shielded. Others have the same problem :>(
arcam delta 290 buzzing Google Search
Jun 18, 2017 | Kenwood Audio Players & Recorders
I have 2 SRM-450v2's. How do I hook it up to my 1604 VL2-Pro Mackie mixer?
You should see a left and right main output on the 1604. Connect these to the line inputs on the SRM450s. Set the input volume control about mid way on the SRMs to start. Vary the volume control as needed to give you the most flexibility and control from the mixer.
Dan
Jul 03, 2010 | Mackie SRM-450 System
Other person cannot hear me
You are in a situation of having 2 mics
Make sure the webcam mic is set as default
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Configure mic to your chat program
Apr 28, 2010 | Logitech Webcam
I want to hook up a an interface to a mackie mixer. What is the common denoinator to hook up, let's say a digi 002 and a mackie mixer so i can have a mac computer with pro tools operational with also the...
you can just piggyback the mixers - take the outputs from the mackie mixer (assuming it is NOT a powered mixer) ... those should be line level outputs - send them into a line level input on the digi 002 and then set that channel on the digi 002 and once set, just leave it, and control the mackie channels individually ... should work fine ...
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.rexark.com
Oct 14, 2009 | Digi 002 Rack FireWire-based Pro Tools LE...
Side by side
Suction at door is caused by the rapid reduction in air volume after you have had a freezer door open and then close it. The refrigerator door side does not have as pronounced air reduction volume due to less temperature difference.
Test you door gasket seal by closing the door on paper (dollar bill) works fine. If you have resistance when sliding or pulling on the paper you have a good seal. No resistance means your door is not sealing properly.
Apr 29, 2008 | Frigidaire FRS23H7C Side by Side...
MACKIE SWA1801--Sound quality is not same
I suggest, go out and buy a heavier duty 18 and replace it.
Aug 24, 2007 | Mackie SWA1801 Subwoofer
Mackie SWA1501 Subwoofer Logo
288 people viewed this question
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
