Question about Dayton 511 Utility Heater
Heater Problem Why does it only stay on with the shell cracked open?
  • 625 Answers
The fan might be hitting the shroud - cracking it open the shroud frees up the fan.
Posted on Nov 26, 2007
Francis Francis X1. Why does it work sometimes and sometimes heater trips GFCI?
take it to an appliance repair shop to have it checked out
the trip is working but if you ignore the problem you may get electrocuted
Dec 25, 2015 | Coffee Makers & Espresso Machines
I put my 1989 Honda Prelude engine (auto) into a 1988 shell with manual transmission, and now my revs stay high only when driving and changing gears. Was wondering if it is a vacuum hose issue and how
may need to swap the computer also.. manual computer is different..but yes.. be looking into any vacuum leaks..block off any open ports you find..
Dec 09, 2013 | 1989 Honda Prelude
Defrost on my 2002 Cavalier will not work properly. Will melt ice off windows in the winter, but the side windows stay foggy unless I crack open a window.
your car's interior is wet-damp and is not being allowed to evaporate. Leave your windows cracked open in the garage a few day...and/or dry out the carpet or mats with a heater-blower.
Oct 31, 2013 | Cars & Trucks
I have Rheem model 41V50 leaking from the top...The top is a lid with screw....can I buy and replace the top ?
No.
Replace tank.
Buy 40 gallon from local Lowes and install yourself.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Under thin metal shell is a welded steel tank, surrounded by insulation and then covered with painted metal shell. The shell is what you look at.
The inside steel tank is made to withstand high pressure expansion that comes with heating water.
The steel tank has rusted out.
Turn gas control valve to vacation, so pilot light stays on, and then only heat enough water as needed until you can replace tank.
Prevent next tank from rusting by replacing anode rod, and ground water pipes.
http://waterheatertimer.org/How-to-maintain-water-heater.html
Apr 09, 2013 | Rheem 50 Gallon FVR NATGAS Water Heater...
Water temp stays at 160 degrees
Specific type of water heater does not show on web search.
I am guessing you have tank-type electric water heater.
Did you replace both thermostats and test elements?
Element could be cracked, thermostats can stick open, upper thermostat wired incorrectly, wire shorted.
We know that electric power to water heater is good, and circuit breaker is good.
Why is eco is not tripping? Why is TP valve is not leaking?
Copy following links for step-by-step:
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Jul 21, 2012 | Rheem Water Heaters
Will a crack in the shell make the heater leak??
If the metal has cracked, it is only a matter of thime before it starts to leak. I wouldn't use it unless you are home. If it does leak, it can cause the heater to overheat and be a potential fire hazard
Jan 28, 2010 | DeLonghi 6707E Oil Filled Radiator Heater
Crack near hinge in nintendo ds
Yes, go to www.powergamingparts.com and order a new shell. They have manuals that will help you successfully open and replace the shell. If you need further assistance please contact me.
Oct 07, 2009 | Nintendo DS Console
2000 bravada heater core replacement
Did you disconnect the 2 hoses running to the heater core from the exterior? PS dont open that shell until you get the whol thing down,
Oct 20, 2008 | 2000 Oldsmobile Bravada
Dayton 511 Utility Heater Logo
53 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
