My friend is a part time mechanic he gets his solutions from www.reliable-store.com
he gets from their every single detailed info, instructions etc. on all vehicles, and manuals like service, repairs, parts, owner's, operations, maintenance etc.
U can get help from there
there is a girl at chat she can help you
SOURCE: P0441 EVAP Emission Control System Purge Flow Fault 2001 Accent
It is always best to start simple on a lot of these things. This code indicates that somewhere in the evaporative system you have a leak that has set off the code. The gas cap is the most common culprit and that is where I would start. Buy a new gas cap and put it on. It may and should solve your problem. A lot of gas caps have rubber seals that do wear out over time. If this does not solve your problem simply use a search engine and type in p0441 a wealth of information will pop up. There are other possible causes and solutions but that's where I would start (with the gas cap)
SOURCE: what is the drive cycle for an 01 pontiac aztec?
if there is really no problem with all these things they should be able to clear out the lights when they go to do the inspection.
SOURCE: hyundai sonata 01 jerking slow take off high idling
P0715 = Input Shaft Speed Sensor Malfunction
P0765 = P0765 Overdrive solenoid valve problem
The Input shaft speed sensor is located on top of the trans (center) under the shifter cable (the shifter cable is connected to the transaxel range switch). The Overdrive Solenoid valve is located INSIDE the trans (oil pan must be removed to access it).Go to http://www.hmaservice.com/ and register (vehicle by VIN). Afterward, you'll have access to technical information (manuals, wiring diagrams, service bulletins, etc) about your vehicle.
SOURCE: 01 dodge ram 1500 5.2 4WD code P0455 evap system leak.
This code will not stall or no start of your engine, evap only work when engine is off, it is to reduce the fume your gas tank lets out to protect the o zone, but it will not pass Emission test, also could be some thing a small as your gas cap not sealing right.
SOURCE: my code for my 2000 hyundai accent is: P0442 Evap
may have a leaky vacuum line somewhere. The rubber seal on the gas cap could be cracked or worn out. they are easily replaced.
